Toyota FBCU20 No lower
I have this unit that has all normal functions, no codes. Have freelift and main lift, it will lower first three stages, will not lower in free lift range. Cracked line at base of cylinder and will lower, anyone have any suggestions?
Thanks in advance!!!
David
  • Posted 3 Jan 2013 03:38
  • By 1sharpdog
  • joined 20 Apr'12 - 220 messages
David Sharp
Have a Great day and thanks for all the great advice! sharpforklift@gmail.com
Very funny 7777. First want to thank everyone for their help!! The final solution was indeed the load holding solenoid. Was redecent in buying one, very pricey, but turned out to be the problem. Thanks again!!!
  • Posted 14 Jan 2013 06:06
  • By 1sharpdog
David Sharp
7777 said; "but to get soaked w/ oil is a very dangerous manuveur. Dont do that again."
and i say;
if you do it again, please get someone with a cell phone camera to take a movie and post it on youtube and give us a link, thanks, we want to share with you.
  • Posted 4 Jan 2013 21:53
On a 7 series 4 wheel there is a load holding/lowering valve/solenoid assy that can fail and cause the issue you're having. It gets stuck closed partway so the 2nd stage will lower (although slowly) but in freelift can take forever. But like the poster above me said there is a manual lowering valve that bypasses this assy.
  • Posted 4 Jan 2013 13:57
  • By JimConnected
  • joined 23 Jun'11 - 15 messages
If ti is a 7 series 4 wheel it should have a manual lowering valve in the hydraulic control valve. If memory serves me right it is at the bottom front side of the valve, just above the lift solenoid. It should be a bolt with a jam nut, loosen up the jam nut, push lift lever to lower, than loosen the bolt slowly until the forks come down. If that work than there is a valve hanging up.
  • Posted 4 Jan 2013 10:39
  • By rogeriwt
Is the orifice check valve inside the FFL cylinder.
Whats your email?
  • Posted 4 Jan 2013 08:47
  • By 7777
Let me begin by thanking you very much for your inputs and assistance. To review my troubleshooting, when I did crack the return line from FFL cylinder, on the manifold, forks immediately came down. Now does'nt that eliminate all components from cylinder to manifold? That is what has me confused, especially with the manifold components in seemingly "good" condition.
  • Posted 4 Jan 2013 08:43
  • By 1sharpdog
Try running the truck w/out the guts of the valve just to check the issues. Or break each line at different intervals in the circuit to see basically where the problem lies. If the truck drops the secondary cylinders ok, then it should drop the FFL cylinder.
The problem, as you stated, was in the FFL cylinder, so my guess is that it would be at the bottom of the FFL cylinder.
Give a try, you'll figure it out
  • Posted 4 Jan 2013 08:11
  • By 7777
I think I ran into that problem on a 8 series LP unit. This is a 7 series, 4 wheel sitdown Toyota with no SAS. Again removed valve. Does anyone know what to look for, because the first time I disassembled, springs seemed in good shape as well as the spool valve and poppets. I really need help on this one guys!!!
  • Posted 4 Jan 2013 07:41
  • By 1sharpdog
The 8 series gas trucks had a bulliten that refers to issues w/ the control valves. One would have to remove the control valve and remove the lower portion of the lowering valve. Then insert the replacement part. This all due to a broken spring that the old part/part# was recalled on. Call the toyota dealer and they'll know if there is a recall on the 7 series electrics
  • Posted 4 Jan 2013 04:34
  • By 7777
If in fact the problem is in the control valve [assuming that your have a 7 series truck with SAS] The problem is most likely in the lift select solenoid. We can trouble shoot and repair these valves. Should you have any questions drop me an email. keith at aztechydraulics dot com
  • Posted 3 Jan 2013 23:20
  • By Keefer
  • joined 22 Jun'05 - 9 messages
To crack a line while the forks are in the air is one thing, but to get soaked w/ oil is a very dangerous manuveur. Dont do that again. The problem is somewhere between the lower part of the FFL cylinder and the return end of the control valve, (assuming the cylinder stages are all operating in the lift properly). Investigate alittle and you'll find it.
  • Posted 3 Jan 2013 20:52
  • By 7777
Well, I decided to remove manifold, what a task! I left the forks up a little to see if they would lower when I removed the return line. After getting doused with fluid, forks immediately lowered rapidly. Disassembled all valves and poppets and did find minor amounts of debris, no big stuff, springs all seemed in good shape. Reassembled and installed........same problem. Does anyone know if they rebuild or remanufactor the valve.....if that is indeed the problem. Please assist with any more suggestions, and thanks 7777! Also, springs were not broken, but could they lose there recoil pressure?
Thanks all!!!!!!!!!!!!!
  • Posted 3 Jan 2013 09:37
  • Modified 3 Jan 2013 09:38 by poster
  • By 1sharpdog
David Sharp
you might want to check along the main hydraulic line for a "valve of sort". Sometimes the flow "check" valves break internally, or get dirt in them and seize.
  • Posted 3 Jan 2013 08:02
  • By 7777
Deborah Baker Deborah Baker
