error codes
hi, i picked up a clark c30l, and i dont know how to read the error codes. i replaced the throttle control and the throttle body and it wont reach maximum engine speed, it keeps cutting out, and then the check engine light flashes, i just dont know how to read the code. any help is greatly appreciated. thanks
  • Posted 17 Oct 2012 11:39
  • By gary_s
  • joined 17 Oct'12 - 1 message
  • New Jersey, United States
try cleaning the FTV valve or valves if it has it, or it may have 2. use gas to clean and air dry
  • Posted 24 May 2015 04:08
  • By edward_m
  • joined 11 May'15 - 111 messages
what fuel system does it have? Woodward or Juniper. Should say on the vaporizer. You can get the flash codes out by: turning on the key (dont start it) and pumping the throttle 3 full strokes in 5 seconds. just pump it 3 times quickly. write down the codes and maybe i can help. Newer systems have 3 digit codes, older ones have 2 digit. code 12 is the first and last code.
  • Posted 12 May 2013 01:56
  • By dale_mc
  • joined 12 May'13 - 12 messages
  • Alberta, Canada
Bolzoni SpA (Group HQ)
