Starts but will stall out after a while.
It will start and stall out after a while, will stay running at times for 15 or 20 minutes with no problems then will start to have problems staying running. I live in Terryville Ct and does anybody have any ideas on how to fix this or a person that can work on this.
  • Posted 16 Oct 2012 04:30
  • By ludlow
  • joined 15 Oct'12 - 7 messages
  • Connecticut, United States
Thanks...I will let you know if that works...
Jim
  • Posted 20 Oct 2012 10:50
  • By ludlow
check the LP converter while truck is running and see if it is freezing up when this condition starts to occur, usually you can see the freezing up beforehand though. It will get a film of white ice on it like frosting up.
If it is freezing up then you either have a bad converter or the coolant in the system is low.
  • Posted 16 Oct 2012 21:30
  • Modified 16 Oct 2012 21:31 by poster
Michel Denis Michel Denis
RAEDER-VOGEL
