Raymond code 26
Code 26 easi reach.
  • Posted 23 May 2012 04:32
  • By paul10
  • joined 18 May'12 - 15 messages
Showing items 1 - 20 of 30 results.
Thanks for all the good advice, all fixed and working now! Only issues were blown fuse and just 1/2 hr. Ago found some light corrosion on the steer encoder cable plug. Got some contact cleaner and brush on that and the beast rolls where I steer it now, and all checks out. I was able to do the learn steer because the wonderful previous owners never changed either password, 1 for operator and 2 for superword. The regrettable thing was the first day I worked on it, I unplugged and checked a lot of plugs including that one, saw a tiny bit of white powder at base of one prong, and ignored it, but that was the one.
  • Posted 31 May 2019 05:58
  • By Cannonmn
  • joined 26 May'19 - 22 messages
  • Virginia, United States
I've been working on these trucks for 20 years it's really not that bad.
You won't be able to run a learn without superword as you know but learning a broken truck won't fix it.
You need to verify the motor is being powered. You can do this by jacking the drive wheel off the floor and with the truck off manually push the drive motor to one end (full lock) and then power the truck on. It will auto center the steering every key cycle. If it doesn't move turn to opposite full lock and try again.
If it moves one way and not the other or does nothing it will narrow down troubleshooting.
  • Posted 31 May 2019 04:12
  • By stam
Today's festivities will include the "learn steer":procedures outlined in my rough notes from the manual:
EASiTM Orderpicker Maintenance Manual Systems Overview Modes of Operation LEARN Steer ACAUTION Run LEARN Steer to calibrate the steer motor Prior to LEARNing height and weight, the vehicle should be placed in an arearcuits. where the platform is able to lift beyond the upper mast reference switch (156 ir [396 cm] plus the height of the carriage) assembly with the electronic steering control NOTE: Before beginning this portion of LEARN jack the tractor up so the drive tire is off the floor When HT/WT is selected, the following message appears A WARNING CARRIAGE WILL AUTOMATICALLY LIFT/LOWER BETWEEN THE REFERENCE SWITCHES Use extreme care whenever the truck is acked up for any reason. Never block the truck between the telescopic and the floor. Use a suitable hoist to stabilize the mast. Keep hands and feet clear from beneath the vehicle while jacking. Use jack stands or solid blocks to support truck do not rely on jacks. Refer to page 2-11 The operator is prompted as follows STEP ON DEADMAN TO BEGIN This message will scroll continuously until the operator steps on the deadman. After the operator steps on the deadman, the carriage will immediately begin to lift. The display will continuously scroll the following message TO ABORT, STEP OFF DEADMAN 1. Select STEER from the LEARN menu. The If all the parameters measured during LEARN are within tolerance, the following message will following message will appear: JACK UP DRIVE UNIT AND BLOCK VEHICLE READY? appear 2. After the f truck is jacked and blocked, press ENTER. The following message will DONE LEARNING HEIGHT AND WEIGHT If, at any time during LEARN, the operator steps off the deadman pedal or th outside a tolerance, the following message appear: e measurements fall STEP ON DEADMAN TO START TEST 3. After the deadman is depressed, the following message is displayed: appears UNABLE TO LEARN... LOWER THEN PRESS ENTER TO LEARNING STEER UNIT, TO ABORT PRESS ENTER CONTINUE For optimum responsiveness of the steering, the ESM needs to know the power required to move the drive unt and the speed at which the drive unit rotates when steering. During LEARN Steer, the ESM calibrates its steer motor contro. If the failure is not the result of stepping off the deadman, attempt to learn again. If repeated attempts to learn fail, run tests:. Test A05 Pressure Sensor Voltage (Page 6-121) circuits to the individual characteristics in the steer system to optimize the operation of the steering.. Test 100 Lower Mast Reference Switch (Page 6-148) The following is a description of what occurs during LEARN Steer Test 101 (Page 6-149) Test 110 Display Flow Sensor Count (Page 6-156) (use active maintenance) 1 Upper Mast Reference Switch. The CCC informs the ESM via BUS+/- to begin LEARN Steering. The ESM Auto Steer centersthe drive unit. PDMM-0101, Issued: 6/18/03 3-15...
Sounds like fun, doesn't it?
  • Posted 31 May 2019 01:01
  • Modified 31 May 2019 01:02 by poster
  • By Cannonmn
Yes 84 just required me to lower Jack I'd used to jack up the vehicle as required for maintenance mode, which I never got into for lack of password.
  • Posted 30 May 2019 09:50
  • By Cannonmn
Sorry you have orderpicker thread was for reach.
84 is mended already I assume
G3 your steer motor may not be turning.
  • Posted 30 May 2019 08:38
  • By stam
Good self-test but get code G3 when press deadman.
  • Posted 30 May 2019 07:44
  • By Cannonmn
Jumpered fuse with a 60 amp one, closest avl, ran self-test, now I've got CODE 84. Going to get manual. How fun this is!
  • Posted 30 May 2019 07:07
  • By Cannonmn
Thx for fuse pix, found it and Mr. Fluke says it is open! No wonder I couldn't find it on the %#$@&*('l power panel, it ain't there, is on top of the relays. Gonna jumper it and see if I get a sat self-test.
  • Posted 30 May 2019 06:56
  • By Cannonmn
Power steering working? I'll re-post the status. Machine doesn't pass self-test, so nothing related to machine moving around is operable, including steering. Do you know where the F8 fuse is located, I couldn't find it.
  • Posted 30 May 2019 06:43
  • By Cannonmn
Gave up on FU8, no such animal on the power card!
Continuing the process, I folded the manual to get in the program, then maintenance modes. The system requires either a password or superwrd to get in. I don't have either, and pressing enter with no entry just gives an error message. If Raymond won't give me an access code, looks like I'm screwed as far as fixing it myself.
  • Posted 30 May 2019 06:38
  • By Cannonmn
If power steering is working that fuse is good.
Google images: JJN70 - that's the fuse.
  • Posted 30 May 2019 04:56
  • By stam
I'm into 2nd hour of searching for FU8 on the power card. Nothing on it looks like any kind of fuse to me. So is it somewhere else, or maybe doesn't look like any kind of fuse I know?
  • Posted 30 May 2019 04:41
  • By Cannonmn
Thanks, S1 and S2 are ok, very low resist. Between when removed. No shorts to frame on either wire. What does FU8 look like, and is it on power card? Can't seem to find it. There's a suspicious, empty white plastic holder strap, unbuckled, that looks to have held something cylindrical about an inch in dia. I see from schematic that TP7 is one of that fuze's connections, I'll look for that one.
Also, "Check the power card and TM's as per the book."
Book I think sends me to test A14. That test has to be done with machine in maintenance mode; we'll try that today. Also the cards in the rear compartment (all cards but one are there) are dusty even though they stay in a steel box. The box isn't airtight so it seems dust gets in the loose cable penetrations easily. I'll put some air on the dust at 30 psi, and blow some on the motor brushes too.
  • Posted 29 May 2019 06:01
  • Modified 29 May 2019 21:30 by poster
  • By Cannonmn
Also make sure the 70 amp fuse (FU8) is good. It feeds power to the TM's.
  • Posted 28 May 2019 23:37
  • By justinm
Have you checked the transistor modules behind the power card? The code is an open in the field circuit. Could be bad cable connections on the motor, a power card, a bad TM. First step is make sure your motor circuit is good. Remove the S1 and S2 cables from the power card and test from one to the other and make sure you have very low resistance. Make sure you don't have shorts to frame on them either. Check the power card and TM's as per the book.
  • Posted 28 May 2019 23:35
  • By justinm
Latest: I turned the key on with all covers off, and here's the light display on various cards:
Carriage control card: one steady green light.
Power card: upper-three small lights in line and touching: yellow, yellow, green left to right. Middle: Blinking red light with caption "Steering control." Bottom: Steady green light.
Does this tell you what's wrong?
  • Posted 27 May 2019 12:16
  • By Cannonmn
Some notes I made when reading about Code 26 in the manuals-many points already mentioned in this thread but a couple may be new here. I can't recall a low battery having been mentioned.
EASi Orderpicker 26 Fault Codes Code 26 Code Title Open detected in field circuit Reason Current was not detected in the field circuit when it should be System Response 1. Alarm sounds: Yes 2. Operator's Display: CODE 26. Inform Service 3. PC contactor: De-energized 4. Speed Limit: 0.0 mph If cycling the key switch Off/On does not clear this code then follow the procedure below How to Clear Corrective Actions and Checks 1. Check the battery charge. A low battery in combination with heavy activity may cause this code to appear. 2. If the problem is intermittent, the cause may be noise spikes. Check the follow- ing Make sure that there is an insulator between the horn bracket and the tractor frame.The horn may be shorted or the varistor on the horn may be bad. Try a different horn assembly Check the snubber circuit for Q1 (REC3, C1, R2) Check the snubber circuit for Q2 (RECA, C2, R3) Run Tests. A14 - Field Current Sense Voltage. Refer to page 213 004-Forks First Enable Signal. Refer to page 273 005-Tractor First Enable Signal. Refer to page 274 O13 - PWM Ramp. Refer to page 286. Possible causes 1. Check FU8. 2. Check the cable from the field windings to the Power Card. 3. Check the resistance in the field windings. The resistance should be 1 to 2 ohms 4. Check the connection behween the Power Card and the Tractor Manager. 5. Check for voltage to frame per page 391. 6. TM1 and/or TM2 (transistor modules) may be bad.
  • Posted 27 May 2019 05:38
  • By Cannonmn
Is the $39.95 offering from the "Warehouse IQ" site going to give me the manuals I need to troubleshoot the Easi opc 30tt? I'm asking because in searching for manuals online I found some, such as musiczum, that were fraudulent. The warehouse site's I'd for the Raymond manuals package is: raymond-forklift-repair-manuals-for-series-easi-pdmm/
Edit: I bought the 4 manuals package and it seems to be as described in the ad., some 44 mb, zip file. I've already answered some of my questions after having the books for only a couple of hours.
  • Posted 27 May 2019 00:28
  • Modified 27 May 2019 04:51 by poster
  • By Cannonmn
Is it correct to have an empty blind threaded hole about 1" dia. In the aluminum heat sink block? There are two such holes, but only one is occupied by a component. I have a photo but it seems the forum doesn't do photos or links to them.
Edit: Bought the four manuals and a diagram and parts list answered that question. Item 4 is apparently omitted in mine, the single-speed version, but is required in the variable speed one. Item 4 is a diode.
  • Posted 26 May 2019 21:25
  • Modified 27 May 2019 04:48 by poster
  • By Cannonmn
Deleted by auth
  • Posted 26 May 2019 10:20
  • Modified 26 May 2019 21:21 by poster
  • By Cannonmn
Briefs United States
Maxlion FD30
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
