linde h25d very hard to start
is there a glow heater in these trucks if so where
turns over good and then drains the battery down
fuel going through ok or anything esle to look for?
  • Posted 6 Jan 2011 09:58
  • By greasespoon
  • joined 30 Jul'09 - 154 messages
  • somerset, United Kingdom
The truck is a 351 series. The older trucks were equipped with Deutz F3L912W engines which had glow plugs. The newer version had a Deutz F3L913G engine which did not. Take a look at your intake manifold to see if there is a plug in it. If it does you can get an intake manifold heater from your local Deutz distributor. If not there is not much that you can do. They do have magnetic oil pan heaters but you would probably have to pull the engine in order to put it on since this truck is outfitted with a belly pan.
  • Posted 12 Jan 2011 22:36
  • By duodeluxe
  • United States
duodeluxe
engine is a 3 cylinder deutz
  • Posted 12 Jan 2011 09:38
  • By greasespoon
Hi what is the truck serial number?
  • Posted 7 Jan 2011 01:44
  • By Herald
  • joined 3 Jan'07 - 128 messages
  • lancashire, United Kingdom
