Height error
Working on a hyster order picker with height encoder error code. curtis system. Wiring ok, runs slow. Not sure how to reset height encoder. Mit, linde, clark, kalimar,and Taylor Tech
Thanks stu
  • Posted 1 Dec 2010 12:51
  • By studog
  • joined 8 Oct'10 - 12 messages
This one drove me nuts for a long time
Found the the lowering flow control faulty ,it sits behind the main
Lift hose fitting in the aluminum valve body.
Look at the flow direction arrow when removing.
When the flow control goes bad the unit lowers slower than should
And the encoder doesnt count properly.
To check quick,if you have another picker handy
Put them side by side and lower them at same time
Both should be close to equil,the slower one is always the one with a faulty flow control.
  • Posted 5 Apr 2019 10:03
  • By Pistolpeted
  • joined 15 Dec'18 - 34 messages
  • Connecticut, United States
do you have access to the dash display setup menu? If not you will probably need a dealer technician to reset the encoder.
  • Posted 30 Oct 2018 05:21
  • By BREWSKI
I have one with the same code, no travel or lift. Encoder and "curly" cable have been replaced. Overmast cables ohm ok and prox lights yellow when turned on. Any help would be greatly appreciated.
  • Posted 30 Oct 2018 04:04
  • By buddy_j
  • joined 30 Oct'18 - 1 message
the error code can be caused by several different things, the encoder, wiring, prox switch, or unit setup. are you familiar with entering the setup menu on these units? if so, check to see if the unit is set for largebox , also, try raising platform past 24" prox sensor and lowering back down.
  • Posted 9 Dec 2010 14:40
  • By grumpy
  • joined 17 Apr'10 - 13 messages
Sue Tomic Sue Tomic
