lift interupt how do you shut it off
I recently purchase an e50xl hyster scr control lift. before purchase everything worked fine. after i picked it up the trucks battery was pretty low so i wasnt suprised when the lift pump shut off. well i charged the battery and still no lift motor. the contactor is not functioning. what else could it be.
  • Posted 25 Jul 2006 12:38
  • By brandon_j
  • joined 25 Jul'06 - 1 message
Yah, we need more details...
If it has ev100LX then the bdi is controlled through the traction card, and can be adjusted somewhat.
A straight ev100 non-lx will have a curtis bdi assembly that can also be adjusted for cutout and reset.
(the difference is the display, only the LX trucks have the little led display that shows hours, codes etc.)
I suspect the problem is simply the reset voltage.
The bdi's won't reset to 100% until the battery goes over a certain voltage. If that voltage is too high, or the charger shut-off too many hours before, the guage won't reset.
Just reset the charger, and after a short time (10-30 seconds) unplug the charger and quickly plug the battery into the truck.
If that fails to solve the problem, we'll definatley need more info...
  • Posted 28 Jul 2006 14:19
  • By mike_n
  • Alberta, Canada
Check all fuses and power cables to the lfit motor first. I am not sure what contactor you are talking about because I don't think an SCR lift truck has a lift contactor.
  • Posted 26 Jul 2006 09:22
  • Modified 26 Jul 2006 09:24 by poster
  • By Liftdoctor
  • joined 22 Jan'05 - 115 messages
  • Indiana, United States
Sue Tomic Sue Tomic
Sue Tomic Sue Tomic
Sue Tomic Sue Tomic
