Unit gives code G4
Hey, can anyone help me with a raymond code G4 easyopc30tt 2005 model.
  • Posted 5 Oct 2010 09:11
  • By jerry_c
  • joined 5 Oct'10 - 26 messages
Showing items 1 - 15 of 15 results.
Make sure your lift truck battery is good shape and also check static straps. I have a customer who has 14 Model 5600's and i had to replace 4 steer amps on different trucks in same month. All 4 trucks were missing static straps and batteries were in dire need of watering. They had watering systems installed , but still need to do cell to cell checks periodically.
  • Posted 2 Sep 2011 19:32
  • Modified 2 Sep 2011 19:35 by poster
  • By ross_g
  • joined 12 Jul'05 - 18 messages
Yup...that seems to be the usual culprit. Same with GD codes on the 7400!
  • Posted 18 Aug 2011 06:29
  • By joe_d
  • joined 25 May'10 - 253 messages
Ain't nothing I can't fix but a broken heart and the break of day!
Never mind it was the steer amplifier!
  • Posted 18 Aug 2011 06:09
  • By Gixxerfix
  • joined 15 Mar'09 - 2 messages
Thank you for the info. Your input has helped us solve the issue. Thanks again.
  • Posted 13 Aug 2011 03:17
  • By jerry_c
  • By jerry_c
I have a 560 opc30tt 2007 with g4 code on start up.then after startup with the dead man pressed it codes g3 are their any test that can check the encoder pulse. Or test for the steer amplifier?
  • Posted 13 Aug 2011 03:06
  • By Gixxerfix
I have 06s, 08s, and 10s. Same diagnostics and you'll find it probably the same thing. Make sure to check CR1 on the fuse relay card...if it looks like a resistor instead of just a jumper, change the card before changing the steer amp as it's cheaper. Also, we've noticed if the operator touches the steer tiller during start up it'll pop these codes intermittently.
  • Posted 9 Aug 2011 05:57
  • Modified 9 Aug 2011 05:59 by poster
  • By joe_d
Hey Joe D I have a raymond mdl # 550-opc30tt serial # 550-06-a02753 reading this post and results I assume being a 06 it may be different diagnostics, I am getting a code g4 and g5 intermittenly any info you could pass on would be appreciated thansk Paul R
  • Posted 9 Aug 2011 05:22
  • By PR2005
  • joined 18 Mar'06 - 23 messages
  • Illinois, United States
No problem. Have a good New Year and thanks for the update.
  • Posted 4 Jan 2011 22:53
  • By joe_d
You were right on. Steer amplifier. Thanks again for the help.
  • Posted 4 Jan 2011 10:10
  • By kbiforce
  • joined 24 Jan'09 - 7 messages
  • Arizona, United States
Same meaning for the code but different diagnostics. Run test I29 (neutral steer pulses) it should quickly toggle between ON and OFF. If not attach + lead of your DVOM to JPT6-1 and - lead to JPT6-4 on the vehicle Mgr. With the deadman pedal up you should have <4 volts. If it does replace the VM and if it doesn't it's your steer amplifier or wiring. Usually it will be the steer amplifier.
  • Posted 31 Dec 2010 03:54
  • By joe_d
I am working on a 540-0PC30TT with the same code. Would this be the same diagnostics? Thanks.
  • Posted 31 Dec 2010 03:33
  • By kbiforce
Thanks for the update
  • Posted 6 Oct 2010 11:17
  • By JonG
  • joined 7 Nov'07 - 155 messages
  • United States
Thank you. steering motor had frozen brush in holder.
  • Posted 6 Oct 2010 03:10
  • By jerry_c
Open in the steer power circuit
The electric steer manager is not reading the steer motor current properly.
Run test A22
Odds are it's either the steer motor or the gear on the bottom. If you jack up the truck and wiggle the steer disc on top of the motor does it turn? If it doesnt then check the gear on the bottom of the steer motor.. If thats OK odds are its the steer motor.
  • Posted 5 Oct 2010 10:41
  • By JonG
  • United States
