Error Message: 5 Starter Switch Not Closed
I am trying to find root cause of this error message. I turn key on, motors activate, I place it in forward or reverse - and to this point all is good on the dash, emergency brake is disengaged and dash light is out.
I put into either forward or reverse - no movement. I press the accelerator, tool light comes on and this error code displays.
Does anyone have an idea what is causing this?
  • Posted 26 Feb 2010 04:25
  • By pat_d
  • joined 26 Feb'10 - 2 messages
  • Alberta, Canada
have you fixed this ??? start switch is on the throttle pedal assy
  • Posted 1 May 2010 04:35
  • By kevin_k
