No brakes
Model# GCX30 S/N# GX230-0031-9158
We cannot seem to get any brake pedal resistance. We have changed the brake master cylinder 2 times. The system has two master cylinders one for the brakes and one for the inching. All the parts at the wheel end are new- Wheel cylinders, axle seals and shoes. There are no leaks. We have tried a power bleeder. We have a hard time believing that we have recieved two bad master cylinders in a row. Anyone out there with a suggestion of what we are missing.
  • Posted 26 Jan 2010 22:27
  • By chickenbone
  • joined 28 Aug'08 - 28 messages
Everyone has a friend in the forklift business!!
sounds crazy but pull the boot back on the top of the mc and fill the back side w brake fluid. works about 2 out of 10 times. all it does is improve the backstroke suction and sometimes thats all it takes.
  • Posted 27 Jan 2010 23:12
  • By rick_c
  • joined 30 Jul'09 - 204 messages
technology: (no user serviceable parts inside)
mrfixit is exactly right, you have to bleed theses from the bottom up, and it also helps to bounce the pedel while doing it too. I recently replace a defective M/C on one of these, it was only a few months old, I realized that the M/C was defective when I tried to bleed it as described, and I couldn't get any fluid to flow up past the master cyl. Also I would advise to never push the pedel all the way to the floor until the system is fully bled.
  • Posted 27 Jan 2010 12:57
  • By fixitandy
  • joined 23 Mar'09 - 81 messages
Those things are real tricky to bleed. The best way I have found is to get a new pump type oil squirt gun and fill it with brake fluid. Hook it up with a hose to the bleeder on the wheel cylinder and pump it. Pushing the fluid in and UP to the master cylinder gets the air out. BTW that has to be one the worst brake/inching systems going.
  • Posted 27 Jan 2010 12:20
  • Modified 27 Jan 2010 20:50 by poster
Not from my experience...talking while I was around someone fixing this same series truck...The adjustment in the pedal linkage is very critical...
  • Posted 27 Jan 2010 09:02
  • By CLTL
  • joined 27 Jan'10 - 21 messages
Commercial Lift Truck
Hawker Powersource, Inc.
Oxford Ct, United States
Columbus, United States
