Nissan G002L30CU BJ 2005
Maincontactor doesn't work.
No drive or lift
The message at the dispay is (ACELERAC. TRAC)
(COMUNCA. EQIV)
The accelerator works fine.
Who can help us about this problem or who has some information of these trucks
Cheers
  • Posted 26 Mar 2009 19:30
  • By blackie
  • joined 9 Jul'06 - 52 messages
  • Gelderland, Netherlands
The Hitachi Controllers on the Nissans, if its the one with the 2 logic cards that slots downwards into the panel, then most likely you have a problem on the largeer of the 2 logic cards. We have had them in the past where the tracks corrode away and also being double sided pcb's and with loads of lacquer its difficult to to test. Try soldering the joints on the card.
  • Posted 1 Apr 2009 18:22
  • By elektrodrive
Hello
Its a small Hytachi controller and the print is not good. ( I have changed him with a other truck.
Thanks for the replys.
But some information on pdf good be nice perhaps whe can share something.
Cheers
  • Posted 31 Mar 2009 06:27
  • By blackie
if its any thing like the model i'm thinking of, it will have to black rely's down by the power steering motor. (there a pig to get at or even see)
try disconecting these and bridge them out.
  • Posted 28 Mar 2009 04:51
  • By uplift
  • joined 28 Mar'09 - 66 messages
  • lincoln, United Kingdom
upliftuk@gmail*com (*=.)
Has the truck still got power steering?
  • Posted 28 Mar 2009 04:48
  • By uplift
  • By uplift
I wouldnt mind the information if you manage to get hold of it. In the meantime, do you know what controller this truck uses? As i may have info on the control system depending on what Nissan have used on this specific truck.
Regards
  • Posted 27 Mar 2009 05:12
  • By elektrodrive
