Linde aux hydraulics
New to me Linde H25T-03 H2X351M05526 / 2001 with higher cabin, heater, SVAB PAMM-2000 CAN hydraulics control. It has 4 hydraulic functions on the SVAB controller already but I need more levers and hydraulic outputs. Not going to mess with the SVAB controller but instead add something else. I guess first question is does the valve block have a power beyond port? There is one plugged hole very close to the pressure inlet, but PB should be on the other side of the block.. after all the integrated spools. I cant see any plugged ports there, maybe on the underside.. Has anyone put more hydraulics on Linde before, and where to connect it?
  • Posted 13 Jun 2025 20:46
  • By christian_s
  • joined 25 Nov'15 - 24 messages
  • Pedersore, Finland
I have thought about my options. The electrically controlled valve by the forks for optional attachment would be nice but there are only 3 hoses on the existing hose reel, would need 4 for proper control I think. One fork spreading hose is shared with side tilt hoses. So the 3 hoses going to the fork movement have oil going all directions in all hoses depending on function.. there are 2 pairs normal double acting outputs from the valve block but it gets combined to use 3 hoses going out..
  • Posted 20 Jun 2025 15:49
  • By christian_s
Your not going to be able to do this in the way your thinking, you won't be able to run another set of hoses up the mast.
The Way to fit a 5th function is to fit the attachment and fit a electronically switched valve into the carriage then use 2 functions from that. Run a cable on a cable reel to the valve and wire it into a switch fitted next to the levers so you can switch between functions
  • Posted 18 Jun 2025 05:09
  • By lifter01
  • joined 4 Jul'09 - 462 messages
I should probably have posted this in the Linde forum??
  • Posted 16 Jun 2025 22:00
  • By christian_s
Lift Tek Elecar
Brussels Airport in Belgium, Europe is the world's largest sales point for chocolate, with over 800 tonnes of chocolate sold annually. This averages out to about 1.5 kilograms sold every minute.
Terberg YT223
Autolift E180AT36B-D5-180
