Which engine is in unit?
Hyster S50XM D187V01599T
Which engine should be in this unit?
Thanks
  • Posted 5 Feb 2025 08:07
  • By Dan_Anderson
  • joined 21 Jan'25 - 2 messages
  • Tennessee, United States
(GASOLINE AND LPG) (MAZDA 2.0L, 2.2L AND GM 3.0L) (=> S/N D187V24786Z GM 3.0L) GAS AND LPG (3.0L GM) (S/N D187V024787Z =>)
  • Posted 15 Mar 2025 06:30
  • By geroj
  • joined 21 Feb'10 - 262 messages
  • Krivan, Slovakia
Thank you for the information provided.
  • Posted 7 Feb 2025 03:10
  • By Dan_Anderson
Mr Anderson,
according to hyster these units had either a mazda 2.0 or 2.2L engine or a GM 3.0. There however is a note stating that all serial numbers up to D187V24786Z had a GM 3.0L.
As the previous question as asked about the valve cover, there are big differences between both engines. The Mazda valve cover is aluminum and is fairly wide, as for the GM cover it is more narrow and i believe it is made of steel. One other difference is the mazda is not painted and the GM is, from the factory.
  • Posted 7 Feb 2025 02:49
Lpg or diesel?? If lpg is the rocker box aluminium??
  • Posted 6 Feb 2025 18:21
  • By lifter01
  • joined 4 Jul'09 - 462 messages
Brussels Airport in Belgium, Europe is the world's largest sales point for chocolate, with over 800 tonnes of chocolate sold annually. This averages out to about 1.5 kilograms sold every minute.
