Hydraulic controls not working (no fork movement, no tilt...)
Hi,
i have a problem with the hydraulics on my 2016 Toyota 8FDJF3533, it happened yesterday all of a sudden. I checked:
- all fuses are ok, also the relays
- i checked for any fault cable but all sems right
- pump is not making any noise
- seat sensor is working (the yellow forklift light goes out on the display, when i sit)
- i also checked the limit sensor on the mast, its working
Any clue where to search next would be appreciated. Thanks!
  • Posted 4 Aug 2024 01:30
  • By nejc_k
  • joined 18 Jan'09 - 5 messages
  • SI, Slovenia
Try disconnect ground from battery for at least 30 seconds, then if still nothing, would see if getting power to material handling motor, then trace back to find where power or ground stop
  • Posted 9 Aug 2024 14:18
  • By Matthew_Reed
  • joined 12 Jun'23 - 113 messages
Sue Tomic Sue Tomic
