90531766
Hi all
I have a fault 1953
On checking I get the following output X6.1 no load connected or over temperature.
Any ideas.
Thanks in advance
  • Posted 30 May 2024 03:43
  • By Paddyteclinde
  • joined 3 Dec'21 - 32 messages
  • Ireland
Thanks Tanel for getting back to me.
We got it sorted ,it was a broken wire in the tiller loom
  • Posted 11 Jun 2024 02:11
  • By Paddyteclinde
  • Ireland
Check tiller head switch, platform switch, saftey switch of the guard rails.
Also what is conmected to the x6.1?
  • Posted 11 Jun 2024 02:08
  • Modified 11 Jun 2024 02:09 by poster
  • By Tanel_M
  • joined 18 Jun'22 - 90 messages
  • Estonia
Thanks for your help Fittermax.EJD 220 90502223 I now have a second truck down with same fault 1953. The truck will drive and lift at a very slow speed if you keep the crawl switch pressed.Otherwise the fault shows and nothing works.
Thanks
  • Posted 4 Jun 2024 20:41
  • By Paddyteclinde
  • Ireland
Hi.
No. tillerhead is plug and play. Are you sure it's an EJD??? If I check serial in JETI it's not...
  • Posted 31 May 2024 06:09
  • By Fittermax
  • joined 17 Jul'08 - 171 messages
  • Denmark
Thank's for helping. Contact d-b-a@mail.com
P i s s Work, gone fishing
Hi Fittermax, thanks for getting back to me model EJD 220 90531760.
We have fitted a new tiller still the same , we swapped a tiller head from a truck that was working and still the same fault.Do we need to calibrate the tiller head when we fitted it.
Thanks again,
  • Posted 31 May 2024 01:12
  • By Paddyteclinde
  • Ireland
Hi.
Serial nr. is for a EJC-112z and not EJD. Check your tillerhead...
Regards.
  • Posted 30 May 2024 20:42
  • By Fittermax
  • Denmark
