migajaca kontrolka swiec
Witam kolegów mam problem z wózkiem Linde h70 migajaca kontrolka swiec zarowych po wymianie swiec zarowych wszystkich czujników na listwie wtryskowej dalej miga i wózek po trzech minutach gasnie jesli mozecie pomóc Bede wdzieczny
Please use English Language
Littoral Translation
Hello friends, I have a problem with the Linde H70 stroller. After replacing the glow plugs of all sensors on the injector rail, the flashing glow plug light continues to flash and the stroller turns off after three minutes. If you can help, I will be grateful.
  • Posted 8 Jan 2024 18:40
  • By ANDREJ_MAJCHER
  • joined 8 Jan'24 - 2 messages
  • Poland
NIE POKAZUJE ZADNEGO BLENDU TYLKO INFORMACIA ZA WYSOKIE CISNIENIE NA LISTWIE
IT DOES NOT SHOW ANY BLEND, ONLY INFORMATION TOO HIGH PRESSURE ON THE STRIP
  • Posted 9 Jan 2024 07:05
  • Modified 9 Jan 2024 14:20 by administrator
  • By ANDREJ_MAJCHER
  • Poland
Flashing glow plug light is an engine management fault. It needs plugging into to read the code
  • Posted 9 Jan 2024 06:37
  • By andrew_k
  • joined 17 Mar'07 - 337 messages
  • England, United Kingdom
