Misfire after running good for 10+ minutes
Model: GC25P-5
Engine: GM G424FE
LP
Our Fork lift runs good for ten minutes or so. It then backfires and has trouble starting after it backfires unless you let it set for twenty or so minutes. If it happens to start after a backfire it usually backfires several times before actually running again. Once you get it running after the backfire the acceleration is really low and it moves very slowly. Eventually, the acceleration will pick up and be back to normal but when you go to park it, it usually backfires once you put it in neutral or remove your foot from the gas pedal. Using the clutch and the gas pedal and keeping your rpm's up usually helps keep it running. Once it sets for an hour or so it usually runs smoothly again until you use it for 10+ minutes. It runs great until it doesn't.
Fixed or Replaced
Spark plugs
Wires
O2 sensor
Propane regulators
Inner Air Filter that was destroyed along with the outer filter.
Fuel leaks after the regulator replacement
Air intake
  • Posted 16 Mar 2023 10:09
  • By Brian_Freeland
  • joined 16 Mar'23 - 6 messages
  • Missouri, United States
Brian Freeland
We have the same problem. CG33 G424FE engine dedicated LPG. Bought a few months ago with this issue.
Heaps of stored codes from CO2 sensors to temp sensor etc.etc.
Runs ok cold and backfires when up to running temp.
We have changed spark plugs, leads without any change.
We carried out a leak down test and had a horrible creaking noise, starting with almost full leakage and once the noise ceased, had full seal.
i noticed oil vapour coming from around the valve spring area and was watching the lifter bleed off as well. our cam is showing signs of breaking up on the full lift point. From experience this usually is from constant pressure on the cam.
I am leaning towards bent valves-probably from a mis-timing or worn timing components or the lifters are pumping up.
I am about to order gaskets to do a head R&R and see what that brings up.
I will keep in touch as we go.
Parts are expensive compared to normal passenger cars in a similar configuration. $280 aud for a Thermostat and $190 aud for an Inlet valve.
  • Posted 14 Jun 2023 14:18
  • By CHRIS_COOPER
  • joined 14 Jun'23 - 1 message
Chris Cooper
I seem to remember a service Bulletin on this unit having to do with replacement of the timing belt and if not done when it was supposed to be done causing wear to the cam shaft. Your local dealer should be able to look up the bulletin for you
  • Posted 19 May 2023 01:14
  • By Gerald_Dolan
  • joined 19 May'23 - 1 message
UPDATE: I have replaced all vacuum hoses. I found cracks and lots of dry rot. Along with lots of other little repairs while I was in there.
Changed both O2 sensors because I tested it and the check engine light will stay off now while driving. Until you put it in idle the check engine light pops back on. I was almost certain it was the O2 sensors causing the backfire. It runs much better but unfortunately today after 10 minutes of driving it, it backfired once again.
I bought a compression tester and spark plug tester. I've never done a compression test on anything. What am I looking for on compression when I do this test?
Any other thoughts on the back fire issue?
This doosan runs much better(night and day) compared to a year ago. So, all these little things are definitely improving its performance but I still have my main issue. The backfire after it gets hot.
  • Posted 1 Apr 2023 08:56
  • By Brian_Freeland
Brian Freeland
I removed the PCV valve but continued to backfire while operating. I then inspected the valve and from the research I did. It was working fine and moving freely. I cleaned it up with some brake cleaner and re-installed. Worth a shot. I appreciate the reply.
  • Posted 19 Mar 2023 06:49
  • By Brian_Freeland
Brian Freeland
any updates?
  • Posted 19 Mar 2023 06:17
  • By andrew_k
  • joined 17 Mar'07 - 338 messages
  • England, United Kingdom
Thanks! I will have to research that. I'm familiar with compression tests but have never attempted. I learn as I go though. Any extra advice on what I would need to do these two tests would be great. Thanks for the tips!
  • Posted 17 Mar 2023 12:06
  • By Brian_Freeland
Brian Freeland
It's an LP only not the duel fuel. I'm not an expert but I'm assuming the injectors are only on the duel or gasoline and regulators for the propane?
  • Posted 17 Mar 2023 12:03
  • By Brian_Freeland
Brian Freeland
Brian,
Should the PCV valve not fix the problem, complete a compression test when cold and hot. May need to also do a leak down test. Good Luck
  • Posted 17 Mar 2023 11:09
  • By garland_m
  • joined 16 Oct'09 - 213 messages
  • Virginia, United States
Work Hard and Fish Long
leaky injector, hydra locking?
  • Posted 17 Mar 2023 11:08
  • By Krusty
  • joined 6 Oct'17 - 4 messages
krusty
Thank you! I will definitely try that. I'm not to familiar with that valve but I have located it in my manual. Looks pretty simple. Thanks again!
Still open to more suggestions. I will try Andrew's suggestion tomorrow and see if it cures my back-firing issue. I truly hope it fixes it. I'm ready to stop playing with this piece of equipment. It is my favorite fork lift so, I owe it my attention.
  • Posted 17 Mar 2023 09:13
  • By Brian_Freeland
Brian Freeland
Check the PCV valve, I had one that always backfired on startup. Removed the pcv valve altogether and cap the inlet manifold and the truck was fixed. Think it causes a weak mixture.
  • Posted 17 Mar 2023 03:25
  • By andrew_k
Sue Tomic Sue Tomic
