interrupted lifting
hi, linde e16c-02, lift doesnt working. when trying to lift up or lift down, start to lift fo 2cm and stopping until turn the key offand start again. movement foward and reverse its ok, just lifting issue. sometimes working as usual, but most of the time doesnt lift.
  • Posted 18 Jan 2023 00:02
  • By yonexp
  • joined 17 Jan'23 - 2 messages
  • Macedonia, The Former Yugoslav Republic Of
ysh
I think you have a coil piece on the valve block
the easiest is laptop on it
  • Posted 30 Jan 2023 03:11
  • By michel_v
  • noord holland, Netherlands
unfortunately its not the joystick, i had another joystick to try and the issue is remaining the same.
  • Posted 30 Jan 2023 02:47
  • By yonexp
ysh
More then likely a faulty joystick I've changed lots of them
  • Posted 29 Jan 2023 21:38
  • By lifter01
  • joined 4 Jul'09 - 463 messages
Briefs United States
