Drives forward, but not always in reverse
I Have a Yale GLP040AF which often times will only go into after slamming body backwards against seat while shifting into reverse. Any thoughts or suggestions?
  • Posted 29 Oct 2022 04:39
  • By Eric_Wilson
  • joined 29 Oct'22 - 1 message
firstly, check you fwd/rev signals at the control valve solenoids, also check the switch/s at the directional switch.
If all is ok in both of those areas and the electrical is good then you'll have to check pressures and see if it's a clutch pack issue.
  • Posted 30 Oct 2022 15:31
Crown CG33P5
Terberg YT222
Sue Tomic Sue Tomic
