BDI problem
I've got a W45ZHD that has a charge indicator that starts dropping from full charge immediately after turning off the charger.
I've replaced the cables and batteries with T105s and still have the same problem. I can see the charge percentage drop just by standing there and watching it.
Other than that, it runs fine except when lift cut-out occurs.
Is there something I should be looking at other than the BDI? I was quoted $700cdn so it's not something I want to change without being sure.
  • Posted 20 Aug 2022 04:40
  • Modified 20 Aug 2022 04:40 by poster
  • By sleepywheel
  • joined 18 Jan'08 - 77 messages
  • British Columbia, Canada
sleepywheel at gmail.com
the only way to be certain about the BDI is to hook up to the machine with PC Service Tool and check all the settings related to tbe BDI.
The default spec on the batteries is 110AH rating. If those new batteries are not that then the settings in the BDI/Controller may be wrong causing this issue.
In most cases a default reset on the system will fix any irregular issues but you still may want to verify all the settings are correct before spending that amount of money on a new BDI when it may not be the issue.
Note: doing these suggestions are only recommended after the batteries, battery charger, and all the cables and connections are verified to be good.
  • Posted 28 Aug 2022 00:35
If the batteries have water and are showing charged with your DMM, then the batteries are likely not the issue and the BDI may be faulty.
  • Posted 27 Aug 2022 08:23
  • By Adam_Thrasher
  • joined 27 Aug'22 - 10 messages
  • Oregon, United States
A. Thrasher
No such luck. Only have a multimeter.
  • Posted 21 Aug 2022 13:05
  • By sleepywheel
Do you have a Curtis handset? Check what voltage the controller is reading.
  • Posted 21 Aug 2022 12:16
  • By Yidneck
  • joined 20 Jan'17 - 110 messages
Dreamt I was fixing a machine, then came the paperwork and it turned into a nightmare.
Sue Tomic Sue Tomic
Yale Lift Truck Technologies
