mast dropping
when lifting something heavy in 2nd stage, the mast will drop quickly, not so much in 1st stage. any helpful ideas would be appreciated, thanks
  • Posted 16 Jun 2022 23:08
  • By Steve_
  • joined 4 Nov'21 - 3 messages
steve_22
Hi Steve,
If the 1st stage cylinders are not causing a drop and it is linked to the 2nd stage cylinders then it may be just a seal set in them or a blocked open poppet valve in the cylinder.
Combilift has a simple procedure to test if it is the valve bank, or mast. If mast, then what cylinder is causing the issue. You will need a gate valve.
For free combilift Support you can submit a ticket at https://warranty.combilift.net/technical-support-form/
Hope this helps.
  • Posted 16 Jun 2022 23:24
  • Modified 16 Jun 2022 23:31 by poster
  • By Richard_Irwin
  • joined 20 Feb'20 - 81 messages
  • Monaghan, Ireland
Sue Tomic Sue Tomic
Linde C4230TL5
Nagano NUL120-6
Lift Technologies Inc.
Sue Tomic Sue Tomic
Linde C4230TL5
Nagano NUL120-6
