4 spool hydraulic valve problem
I've looked all over for either a rebuild kit for the 4 spool hydraulic valve or a replacement assembly without any luck. If you raise the forks they go back down about an inch every 5 seconds. I put a ball valve in line and when I raise them and close the valve they stay up so it's not the cylinders. The valve assembly has a small tag on it that says Parker Model: 1503438 and Serial# H0105 0962. Does anyone know where I could find either a rebuild kit or a new one? Thanks
  • Posted 28 May 2021 03:23
  • By Billm
  • joined 2 Mar'13 - 5 messages
Thanks Scott. I'll see if I can get a rebuild kit or a replacement from them since the lift can't be down for that long of time. It's in use constantly even with the forks dropping.
  • Posted 30 May 2021 08:08
  • By Billm
I don't know if you tried a hyd company called astex hyd they are in canada they might have a replacement valve or can fix yours l have sent them valves and they have tested them and repaired them most of the time it only takes two to three days to send valve back as l am in same state as you
  • Posted 30 May 2021 07:14
  • By Scott_
  • joined 16 May'21 - 316 messages
Scott
Jim Tompkins Jim Tompkins
Sales operations, Heli
