E100ZS Fault codes - Help needed
I have a Hyster E100ZS with the following fault codes:
53, 54, 56, 51 & 52
Can anyone direct me to what these error codes mean?
THANKS!
  • Posted 17 Jul 2018 08:05
  • By DustyB
  • joined 17 Jul'18 - 2 messages
  • United States
51 Capacitor volts are too low before line contactor closes.
52 Traction or pump motor speed sensor error.
53 Traction controller does not respond to master controller.
54 Pump controller does not respond to master controller.
56 Mini-lever module or joystick cannot communicate with master controller.
For starters:
check your control and main buss fuses(dont just look at them or use a ohm meter, do a resistance test across the fuse element, it should be close to 0 resistance, anything more may indicate a problem inside the fuse)
also check the power cable connections
check the cable connections on the controllers, look for any melted or corroded areas.
  • Posted 17 Jul 2018 16:09
  • Modified 17 Jul 2018 16:11 by poster
TCM FD80Z7
TCM FD80Z7 1990
Taylor TT300
USD98,500
