Steer wheel spins arounf, never stops
The steer wheel spins continously, unit will drive but as soon as you stop the wheel just continues to spin around. Seems like it can not find home position. Happens as soon as you power up machine. Any ideas?
  • Posted 23 Sep 2016 22:35
  • By Madebiker
  • joined 20 Sep'16 - 7 messages
Hi If you have any old logic card with the software issues, i will share you the details, to solve this issue..
  • Posted 13 Oct 2016 16:48
  • By gopal_s
  • joined 29 Oct'12 - 156 messages
  • karnataka, India
GOP
Thanks. I did recal acceleration, got C016 to go away. Still have issue with the wheel continously spinning. Don't think I have much of a choice but to replace the A5 card.
Thanks again
  • Posted 11 Oct 2016 01:46
  • By Madebiker
A5 is the main controller under the drivers arm rest.
I would recal the accel pot first as error C016 refers to this. The A5 controller is expensive from Toyota/BT. TVH do recon controllers as service exchange units.
  • Posted 11 Oct 2016 01:40
  • By Roibeard
  • joined 2 Mar'10 - 335 messages
  • Dublin, Ireland
Is the A5 card the logic card?
  • Posted 11 Oct 2016 00:54
  • By Madebiker
Thank you. I don't see anything in manual marked as a A5 card. Can you explain where this card is located?
  • Posted 10 Oct 2016 23:35
  • By Madebiker
Hi.. A5 Card is faulty.. Replace A5 with new one.. no need to replace the tachogenerator... Good luck..
RGDS,
GOP
  • Posted 10 Oct 2016 12:30
  • By gopal_s
  • karnataka, India
GOP
C016 is a calibration error for accelerator pedal. Re calibrate, you will need the can key for this.
  • Posted 8 Oct 2016 01:05
  • By Roibeard
  • Dublin, Ireland
After playing with thus some more I was able to get the wheel to stop by unplugging tach. Replaced tach. Unit was operational for about 5 minutes. Now it through a code c016 and wheel is back to spinning again all the time until I unplug tach. I checked for debris under acceleration pedal, clean. Parking brake stays on all the time. I am hoping that the new tach is not now bad. Any ideas?
  • Posted 6 Oct 2016 00:25
  • By Madebiker
Disconnected tach, wheels keeps spinning. Disconnect X24 and it stops until I hook it back up. Disconnecting at controller, both controllers, did absolutely nothing. This all started when I replaced horn button.
  • Posted 27 Sep 2016 21:12
  • By Madebiker
Disconnect the plug to tacho for the steering. It is mounted directly under the steering wheel. The tacho sends a signal to the main controller once the steering wheel rotates. Maybe the tacho is sending a signal even when the steering wheel is stationary.
If problem persists disconnect steering output circuit at main controller. If steering stops then the fault is probably in the controller.
  • Posted 24 Sep 2016 03:24
  • By Roibeard
  • Dublin, Ireland
Crown RD572513TT6860R
Hoist Liftruck F180-36BOX-CAR
