SLOW TRAVEL WHEN YOU TURN SLIGHTLY OFF CENTER
i am having troubles diagnosing this unit as the service manual I have does not go into detail for electronic steering.You can drive the truck in a straight line but as soon as the tiller is turned slightly right/left the truck slows down to a crawl.If anyone has any ideas please reply as Im lost and starting to get an angry customer. serial number of the unit is Z945W0440ZW
  • Posted 2 May 2012 03:32
  • By ray_k
  • joined 1 Jul'10 - 39 messages
RAYK@MIDOHIOFORKLIFT.COM
another question....
what brand of controllers are on it?
are they curtis?
sepex maybe? 2 1243's or 1244's for drive amps with a 1310 (or maybe a 1352eXM) main controller labeled as a lift amp?
Just guessing ;o)
  • Posted 10 May 2012 07:57
  • Modified 10 May 2012 08:03 by poster
  • By Jplayer
John Player Jr
_________________
LiftOne, LLC
Charlotte, NC
Email: jplayer@liftone.net
Is there any switches on the mast? Possibly a speed limit switch for when elevated (or it thinks it's elevated)?
  • Posted 10 May 2012 05:11
  • By joe_d
  • joined 25 May'10 - 253 messages
Ain't nothing I can't fix but a broken heart and the break of day!
Yeah,it says lift amplifier right on it and the truck has no contactors other than a line contactor..but where the two pots connect is a little sticker that says electronic steering,wondering if maybe a part of that controls the steering.This is one of those jobs that you kinda wish the work order never hit your hands.
  • Posted 10 May 2012 01:00
  • By ray_k
ok that small pot is the steering encoder and from the sounds of it it is working
the encoder(as you describe it) on the tiller is probably what yale calls a tach generator, they used those on thier orderpickers also.
inputs from both go into the lift amp? are you sure its a lift amp? and not a steering controller?
As for any supplements? no i do not have any, this model sounds like a new and improved version they designed themselves after the "schaeff" version that had at first when that model first came out.
I'll check around and see if i can come up with anything, or maybe someone else can jump in here and help? guys?
  • Posted 9 May 2012 08:17
  • By Jplayer
John Player Jr
_________________
LiftOne, LLC
Charlotte, NC
There is a small pot on the large drive gear indicating the position of the steer wheel.The tiller is actually a large encoder itself.Im wondering if it isnt the lift amplifier as the inputs from both go into it as well.I dont have the supplement for electronic steering,do you?
  • Posted 8 May 2012 22:03
  • By ray_k
ray,
can you see any encoders on the steering assy anywhere?
or any sensors?
something is tracking where the wheel is positioned and may have an issue. bad sensor maybe? or bad encoder? usually you will get an error code if one of these goes bad , unless there is a mechanical problem with how it connects.
  • Posted 8 May 2012 09:03
  • Modified 8 May 2012 09:09 by poster
  • By Jplayer
John Player Jr
_________________
LiftOne, LLC
Charlotte, NC
It does it in both directions,I have yet to see any codes pop up when the speed is reduced.Dont really want to start poking around without any info.The manual I have for the unit only goes into the hydraulic type steering not full electric.
  • Posted 8 May 2012 00:41
  • By ray_k
if i'm not mistaken this is yales standup version?
mfg'd by schaeff with a yale sticker slapped on it?
are there any codes popping up on the display when you turn the tiller and it goes into slow mode?
does it do this in either direction of steering? both directions? or just one way?
  • Posted 2 May 2012 20:33
  • By Jplayer
John Player Jr
_________________
LiftOne, LLC
Charlotte, NC
Briefs United States
