side shift
Hi guys
New to the game and need a bit of advise if poss
I have a few h25d with odd problems
L222 Comes up but only if you sit on seat ,if you start the oftruck off machine it work guess its the seat switch but this was changed recently ??
Also I have a side shift with no power it is a meyer system and another engineer has told me its the ram seals
They have a circlip on the outside so does this mean the end cap has to be pushed in to find a circlip on the inside ?????? to remove it to allow access to the piston
I am not sure it is this as the joystick has had water in it
thanks
scorpion
  • Posted 13 Oct 2010 14:27
  • By Scorpion
  • joined 13 Oct'10 - 6 messages
  • KENT, United Kingdom
the L222 refers to the joystick not being in neutral when truck started, this usually means joystick is worn and needs replacing
  • Posted 14 Oct 2010 20:23
  • By comet
  • joined 17 Nov'09 - 19 messages
  • Sounty Durham, United Kingdom
edition #1297 - 3 September 2026
In a move intended to provide Pakistan with a basis on which to compete with its global peers as a modern trading economy, Hutchison Ports Pakistan will spend $76m on a major upgrade and electrification of the cargo-handling equipment at its Karachi facility... Continue reading
Toyota 02-2TD20
Terberg RT223
Combilift Ltd
Héctor Guerrero Castañeda Héctor Guerrero Castañeda
Managing director, Jofson
CEO, Robust.AI
Toyota 02-2TD20
Terberg RT223
Phytoplankton create at least half of the world's oxygen production, despite amounting to only about 1% of the global plant biomass. They also respond rapidly on a global scale to climate and environmental variations, so are often used as indicators of marine health.
