Runs only while key is in the start position
FG15 AF31-50145
I got this unit used and there are cut wires and non-standard wires that I don't know where they should go. I saw an older post about the ground, I checked it and it's good. How do I check the resistor? I jumped it but still had the same issue so I'm not sure that is it anyway. The unit has run fine for a long time so the wires that aren't connected may not need to be, any help is appreciated.
  • Posted 9 Aug 2015 04:41
  • By Waterman71
  • joined 8 Aug'15 - 2 messages
  • Tennessee, United States
Next to the air we breath, water is the most important thing we put into our bodies.
Hey I couldn't find the glass fuses, but the ignition switch was bad! Thanks for the good lead.
  • Posted 10 Aug 2015 08:50
  • By Waterman71
there are glass fuses mounted under the hydraulic levers close to the middle. check them. do you have 12 volts at the ignition coil when key is in run position? Key switch could be bad as well. You must follow the wiring back from the ignition coil it should go up to the key switch.
  • Posted 9 Aug 2015 22:46
  • By stam
Hitachi HX64B2
November 3-4 2026 - Houston, United States
Tampa Florida, United States
