Report this forum post
there are glass fuses mounted under the hydraulic levers close to the middle. check them. do you have 12 volts at the ignition coil when key is in run position? Key switch could be bad as well. You must follow the wiring back from the ignition coil it should go up to the key switch.
  • Posted 9 Aug 2015 22:46
  • By stam
Indicates mandatory field
Michel Denis Michel Denis
