no start
serial #64598
Engine will not run unless you hold the ignition switch in the start position. I disconnected the excitor wire from the starter and used a remote start switch, the engine will run as long as the ignition switch is in the start position. I have 12 volts to the coil and distributor with key on. I have 12 volts to the lp converter as long as the switch is in start position. Could this possibly be a shutdown system failing?
  • Posted 6 Apr 2023 07:12
  • By Twj65Srj67
  • joined 25 Sep'20 - 4 messages
  • Arkansas, United States
I would check the distributor tac wire if it is broken it will only run in the start circuit. Check from distributor to computer.
  • Posted 8 Apr 2023 08:15
  • Modified 8 Apr 2023 09:32 by poster
  • By Scott_
  • joined 16 May'21 - 330 messages
Scott
Terberg YT182
Autolift E180AT36B-D5-180
Jason Morgan Jason Morgan
director of aftermarket, Noblelift North America
sales manager of Texas, Taylor Machine Works
board advisor, Humanitarian Logistics Association
lead sales - Northern Europe, Camso Construction
edition #1276 - 9 April 2026
In this week’s Forkliftaction News , we continue our coverage of LogiMAT 2026 held in Stuttgart with a rundown of some of the biggest product launches at the event which achieved record exhibitor and visitor numbers... Continue reading
Giant dragonfly-like insects existed before dinosaurs and were known as "griffinflies". They lived around 317-247 million years ago and had wingspans of up to 71 cm (28 in).
