mitsu LP gas truck runing rich
I have a mitsu FGC 15 with a imco lp system that is runing rich. It starts fine acel slowy fine, but under hard acel conditions it sputers then goes. Has no power under load. I have the program for the system. It shows unit runing rich. Replaced LP mixer govnor and sensors from working unit.installed new regulator. i did ign tuneup , replaced O2 sensor ,coil, and crank pic up.found problem with thermostat and clogged lins on FTP and PTV. repaired those issues and i still have the same problem. If any body can help me it will be greatly apprecated.
  • Posted 21 Jan 2010 09:36
  • By jason_v
  • joined 16 Apr'09 - 20 messages
I checked the timeing, all the grounds and tested all the sensors, also replaced the ecm with a known good ecm. But I think I got it. Below the mixer on the right side of the unit is a cap. i removed the cap and threr was a align screw there which adjusted the air fuel ratio. Useing the computer i was able to bring into spec, and thank you again for all the help.
  • Posted 22 Jan 2010 22:03
  • By jason_v
Had one the ecm was going out.Started popping on occasion then finally just wouldn't take fuel.
  • Posted 21 Jan 2010 22:49
  • By proshadetree
  • joined 23 Feb'06 - 484 messages
  • Tennessee, United States
thanks i'll give it a try.
  • Posted 21 Jan 2010 21:54
  • By jason_v
I've had some Nissan motors act like that when the ignition timing was advanced a bit from where it was supposed to be.
  • Posted 21 Jan 2010 14:27
Enforcer FLBAXT25
Maxlion FD50T
