komatsu lift trucks
have been experiencing several transmission failures on the -14 models with the drum letting go and also on the new -16 models the motor mounts are loose allowing the engine to move and pulling the driveshaft out of the diff. causing to leak gear oil!! anyone experiencing similiar problems????? any suggestions?????
thanks
  • Posted 13 Jun 2007 11:30
  • By corolla
  • joined 13 Jun'07 - 6 messages
Corolla - Yes I can assist, but not by way of this forum. Please see my previous post.
Do work for Ri-Go? If so have your Service Mgr contact me thru Dave C. at KCL
If not please please give me your contact info and I will be in touch.
  • Posted 27 Jun 2007 21:33
  • By Jeff
  • joined 8 Feb'07 - 61 messages
There is nothing worse than a sharp image of a fuzzy concept.
-Ansel Adams
  • Posted 27 Jun 2007 21:11
  • By Jeff
-Ansel Adams
hi jeff ! can you inform me on this motor mount issue please. i have had several motor mount issues on the 16's, transmission issues on the 14's and still waiting on a correction on the failing relay's on the 14's. as it stands komatsu is not looking very good.
thank-you.
  • Posted 27 Jun 2007 10:32
  • By corolla
There is some mis-information here.
Please contact Komatsu Canada (Canadian Dealers) or Komatsu Forklift USA, Inc. Product Support Dept. (USA Dealers) in Covington and they will be happy to assist you.
Corolla - feel free to contact Komatsu Forklift USA, Inc. - Covington
Paul give me a call and I will explain.
  • Posted 25 Jun 2007 03:29
  • Modified 25 Jun 2007 04:42 by poster
  • By Jeff
We just had factory training on Komatsu units and they are aware of problem on motor mounts. They were designed to give in case of motor coming into contact with immovable object. They said something about installing a pin. I'm thinking you can insert bolt into elongated hole to keep engine from sliding backwards. But I personally haven't had to face that problem yet. This was from other tech that attended school.
  • Posted 25 Jun 2007 00:42
  • By MtnMan
  • joined 9 Jun'07 - 8 messages
  • Alabama, United States
We work on anything and sometimes we fix something!
hi paul. it is on the fg25st-16 and ive seen it from 500 hrs and up. when your looking at the motor mount the stud that goes through the frame mount on the bottom side the frame mount and the spacer thats installed the holes are elongated allowing the engine to shift back. also on the top stud that bolts onto the engine mount you will find you can undo them with one hand! i will be very surprised if you take a close look at this and have not have any shifted especially in the hour range yours are in
thanks paul.
  • Posted 16 Jun 2007 11:58
  • By corolla
I have approx 40-60 FD&FG25HT-16'S hours ranging as high as 2400. what models are the trucks your having the problems with also what kind of hours are you seeing the problem. I can contact my rep and see if he is aware of this diff issue. I have -16's leaving daily for cherry harvest, If you trucks are FG25HT-16'S I will pull some in the shop and inspect motor mounts. Pls advise.
  • Posted 16 Jun 2007 03:57
  • By paul
  • joined 15 Jun'07 - 2 messages
  • Washington, United States
thanks guys! i am aware of the driveshaft bulletin and then they spraypainted the bolts after that problem, but it's the actual motor mount bolts loosening and allowing the engine to shift back therefore pulling the yoke out of the diff! on the -14 the snap ring on the clutch drom breaks and jams up the transmission.
have contacted komatsu canada not much tech support over there though.
  • Posted 15 Jun 2007 11:14
  • By corolla
Komatsu had released a technical bulletin 8/4/2006 reguarding -16 trucks drive shaft u-joint bolts. (bulletin# TB2006-007FC) The bulletin required inspection of all 8 drive shaft u-joint mounting bolts. All bolts needed to be torqued to 29 ft-lbs (348 in-lbs). I have a large rental fleet and found most if not all were not properly torqued from the factory. If you would like a copy of this bulletin contact me at 509-577-0500 ask for Paul Martin in service dept. As far as the trans problems with the -14's I have never lost one yet..
  • Posted 15 Jun 2007 07:26
  • By paul
I would suggest contacting your local Komatsu dealer and/or Komatsu Canada.
  • Posted 14 Jun 2007 20:46
  • By Jeff
TCM FD115-3
SMV (Konecranes) 33-1200C
