Hyundai 15BT-7 ac
I had replaced the $4000 "brain" a couple + months ago. I installed a Battery Extra to assist in the sulfate battery buildup. After 2.5 months with the new brain, I am now getting a read out of:
S 246:
MASTER KO
M 19:
LOGIC FAILURE #1
The machine will barely move 3" before it dies.
First, what is this code telling me? Second, would an old battery system cause a new brain to fail due to a "bad cell"?
Thanks in advance.
  • Posted 12 Sep 2019 04:04
  • Discussion started by Kenneth_VanCott
Ken VC
Hola buen dia
Favor tu ayuda, tengo un 15bt-7 Ac con error D 247 can bus KO. Favor algĂșn comentario
Saludos
  • Posted 1 Oct 2021 11:14
  • Reply by Carlos_Gomez
  • GUAYAS, Ecuador
Carlos Gomez
ken (space) fulcrum-acoustic ("dot") com
  • Posted 13 Sep 2019 00:45
  • Reply by Kenneth_VanCott
Ken VC
let's try one more time please:
ken(space)fulcrum-acoustic.com
make sure the minus sign is in there between the "m" & "a". All lower case.
Please and thank you
  • Posted 13 Sep 2019 00:43
Ken VC
mail send, not sure if its the right adress..
  • Posted 12 Sep 2019 23:07
  • Reply by Speedfreak
  • Niederlande, Netherlands
ken fulcrum-acoustic com
  • Posted 12 Sep 2019 22:38
Ken VC
Ken,
Your emailadress is removed, write it down like; name(space)at(space) blahblah.com.
A direct adress is removed. dont use the @ character
  • Posted 12 Sep 2019 22:31
Yes please email any additional information that you may have. I greatly appreciate the feedback and reply Speedfreak.
Sincerely,
Ken VC
[email address removed]
  • Posted 12 Sep 2019 22:18
Ken VC
M= Master
19= logic failure #1: alarm in U,V,W voltage feedback circuit, fault code 19 can occur in both master, slave and pump.
Its a Zapi Dual AC2 drive controller, fault codes 19 # and #2 can occur in (M)Master and (P)Pump controller.
S would indicate a problem in the slave part of a controller, number 246 is not described.
Check motorcables of drive circuit, check main-contacter, check power cables to contrllers.
Chances are you have a faulty drive motor or a short in wiring.
If you need more info, i can email it to you, when i have your e-mail adress.
  • Posted 12 Sep 2019 22:14
  • Modified 12 Sep 2019 22:15 by poster
RAEDER-VOGEL
