How to change wheels?
Need to change the tires/wheels on a W30XTC walk behind machine and have a few questions. Hopefully someone can help me.
I see how the front ones are attached, but no idea what's involved with the single rear drive wheel.
For the fronts.
Do you set the front nuts the same as you would any wheel bearing type of wheel?
Tighten nut till there's slight drag then back off 1/4 turn and install cotter pin?
Need a short tutorial on how to do the rear including a safe jacking procedure.
Thanks in advance!
  • Posted 28 Apr 2016 23:08
  • By steverino
  • joined 28 Apr'16 - 2 messages
  • New Jersey, United States
The drive wheel is held on with lug bolts like most of these types of unit. I believe you tension the load wheel bearings just as you described.
  • Posted 30 Apr 2016 03:47
  • By BREWSKI
Sue Tomic Sue Tomic
Sue Tomic Sue Tomic
TCM FD80Z7
TCM FD80Z7 1990
SMV (Konecranes) 4632CC5
Sue Tomic Sue Tomic
