hard starting in am
Have a lift with a GM 3.oL cranks foor a long time first thing in am then will fire right up there after let sit sometimes 2 hrs same thing cranks will not fire
  • Posted 22 Jan 2010 09:15
  • By neforklift
  • joined 21 Dec'07 - 4 messages
does it have spark when it wont start? if not, turn key on and off repeatedly and see if it sparks when you turn the key off. if it does not spark when it wont spark and it does spark when you release the key, at least try the ground cable. even if it sparks but it is weak (yellow and short). if it has good spark when it wont crank let me know if it has a standard HEI distributor or an electronic spark advance distributor. (HEI has a vacuum advance).
  • Posted 22 Jan 2010 13:17
  • By rick_c
  • joined 30 Jul'09 - 204 messages
technology: (no user serviceable parts inside)
this doesnot do that it just cranks over I tried a new lpg impco system, hoses, vapor hose, cap rotor wire plugs new battery jumper direct to coil from battery nothing seems to work no matter what I do after it starts it wil fire on second spin every time let it sit 2 hrs or the next day same problem, will not fire on starting fluid either
  • Posted 22 Jan 2010 12:40
  • By neforklift
if it occaisionally fires after you release the key, (this only applies to spark issues) add a ground cable between the battery and engine. i know it sounds crazy but it is a common problem with some of the vortec engine trucks and other brands have had this problem. you can also do a voltage drop test between the battery negative terminal and engine while cranking and that way you can see how much resistance is there.
  • Posted 22 Jan 2010 11:21
  • By rick_c
Terberg RT223
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
The hardest substance in the human body is tooth enamel. Its main component, apatite, ranks at level 5 on the Mohs scale of mineral hardness - harder than gold, silver, iron, or (mild) steel.
Terberg RT223
USD1
Chandler, United States
Philadephia, PA, United States
Steve Nation Steve Nation
Senior solutions sales engineer, Numina Group
President, International Federation of Robotics
VP of Corporate Remarketing, Alta Material Handling
Chief executive officer, Peak Technologies
