H80D slow tilt
...I'm having an issue with an H80, that doesn't throttle up when tilting or fork positioning. It throttles up when lifting, but doesn't for the other commands. they are very slow....no codes....went thru everything with the laptop today when I plugged into it..everything looks ok. Hydro fluid is up....pump sounds noisy at idle though
  • Posted 30 May 2014 11:58
  • By ctforkliftguy
  • joined 14 Mar'13 - 48 messages
  • Connecticut, United States
Hello.
did you fix this problem?
  • Posted 11 Nov 2015 08:23
  • By sjoold
  • joined 24 Oct'15 - 25 messages
  • Norge, Norway
Kindly check on the hydraulic control valve solenoid valve may be the one opening for the tilt cylinders is faulty. The bleed the hydraulic system.
  • Posted 23 May 2015 00:08
  • By Oloibiri
  • joined 22 May'15 - 5 messages
  • Nairobi, Kenya
edition #1294 - 13 August 2026
In this week’s Forkliftaction News, we report on Jungheinrich’s H1 financial results and the reasons it has adjusted down its EBIT forecast for the year... Continue reading
UK names its first Logistics Minister Leicestershire, United Kingdom
September 9-11, 2026 - Hanoie, Vietnam
September 16-17, 2026 - London, United Kingdom
ATEX MIRETTI GROUP
Miretti Explosion Proof Systems for Material Handling: for over 50 years, "Ex Atex Safety in Explosive & Hazardous Areas".
Alogotransiphobia is the fear of being caught on public transport without a book to read.
