Error codes
What does error code 60 mean
  • Posted 8 Mar 2014 04:00
  • By Cleo
  • joined 8 Mar'14 - 3 messages
  • Arizona, United States
Hai to everybody. welcome's me
  • Posted 14 Mar 2014 16:08
  • By jessery_j
  • joined 14 Mar'14 - 1 message
  • TN, India
ArihantDigi.Com
You're OK to drive it. Computer cant tell weight on forks as pressure transducer signal is out of range....most likely a bad connection. Rarely a bad transducer.
Not as bad as 6 feet of snow in Ontario to shovel before work...and don't be late!. But in Arizona you have to worry about scorpions crawling in your bed, biting you're butt..in the middle of the night.
I'll take the snow thank you!
  • Posted 14 Mar 2014 10:25
  • By EasiTek
Thanks it probably was 6D
  • Posted 12 Mar 2014 01:09
  • By Cleo
Did you mean "6D" ? no 60 listed. Only 2digit codes are 80,81,84,85,86
All others are like 2F, 6D....
6D is pressure transducer. Most likely bad connection
  • Posted 9 Mar 2014 01:20
  • By EasiTek
Briefs United States
Lift Tek Elecar
Lift Tek Elecar
