Error code 2000-13
Hi guys.
Hope some clever people can help me.
Struggling with s Hyster H155FT showing 2000-13 on the dash. No performance issues whatsoever.
I can't find the proper diagrams etc.
It's a Kubota version.
Any help will be appreciated.
  • Posted 18 Apr 2024 11:49
  • Modified 18 Apr 2024 11:49 by poster
  • By Stephan
  • joined 17 Nov'23 - 5 messages
  • New Zealand
Stephan,
Not able to find anything on code 2000-13. 2000-12 is a comms issue between the VSM and the ECU. The steer column has a comms connection, right side. Using ohms setting on your meter, check between A and B, should read about 60 ohms. Using the volt setting, check between A and C and B and C. They should read about 2.5 volts or total to 4.5 volts. If you do not have 60 ohms resistance, possible termination resistor has failed if you read 120 ohms. Since you have no performance issues, possible code that needs to be cleared. Good Luck.
  • Posted 22 Apr 2024 22:31
  • By Fishmech
  • Virginia, United States
Andreas Schneider Andreas Schneider
Managing director sales & service, STILL
Executive vice president people & culture, Konecranes
Vice president of operations, Hangcha Forklift America
Senior solutions sales engineer, Numina Group
September 9-11, 2026 - Hanoie, Vietnam
September 16-17, 2026 - London, United Kingdom
