Error code 12806
Hi everyone,
does somebody have an idea what this error code is linked to? The lift won't move at all but I can still use the horn.
Code 12806
Forklift is a Yale model ERC050.
Also, if I want a manual with all the codes, is my only ressource the Yale dealer?
Thanks.
  • Posted 30 Jun 2018 02:01
  • By michel_d
  • joined 30 Jun'18 - 30 messages
  • Quebec, Canada
Just to let anyone who would have the same issue know, operators washed the lift in the morning and it wouldn't move after. Couple hours passed and it started working just like that. Guess it was just a problem with some water and when it dried it all came back to normal.
thanks again Brewski.
Mike
  • Posted 4 Jul 2018 02:15
  • By michel_d
  • Quebec, Canada
Thank you Brewski! Will check that out.
  • Posted 30 Jun 2018 02:39
  • By michel_d
  • Quebec, Canada
The VSM is seeing 2 directional inputs at the same time. Check the wiring at the VSM connector. If it is OK, you probably have a defective VSM or it needs to be reflashed. Check to see that there is a static strap on the truck.
  • Posted 30 Jun 2018 02:29
  • By BREWSKI
Yale Lift Truck Technologies
Around 8-10% of people grind their teeth at night. The process is called sleep bruxism, and most people aren't even aware they're doing it.
