Engine revs forklift doesn’t move fwd or rev
Hi all, just recently picked up a 2007 komatsu FG25T-16. Serial 210459A. It loaded onto a trailer fine when I picked it up but when I tried to use it today for the first time it was having a hard time moving in either reverse or forward but more of a problem forward. I checked the tranny dip stick and just the tip had fluid on it. I checked the fluid level while it was running and fairly warmed up. I'm hoping the fluid is just low. I did not see any leaks underneath. What type of fluid does the transmission use. I do not have a service manual. Please help, thanks
  • Posted 23 Jan 2020 14:29
  • By Romie_Rome
  • joined 23 Jan'20 - 4 messages
The 'A' prefix or suffix does mean built in the USA, but they have never used Dextron. The O&M manual calls for a TO10 fluid.
  • Posted 22 Mar 2020 06:47
  • Modified 22 Mar 2020 06:47 by poster
  • By Jeff
  • joined 8 Feb'07 - 61 messages
There is nothing worse than a sharp image of a fuzzy concept.
-Ansel Adams
All KOMATSU forklifts use a TO10 oil in their transmissions which is not typically not red in color.
  • Posted 22 Mar 2020 06:45
  • By Jeff
-Ansel Adams
Just wanted to provide an update. I added almost a 1qt of dexron fluid and the trans shifted much faster. Haven't had a chance to really use it for an extended period but it's seems to be working normally.
  • Posted 23 Feb 2020 08:41
  • By Romie_Rome
It looks like the drive plates are worn loosening pressure and slipping which is y forward is worse
  • Posted 23 Feb 2020 07:22
  • By Firerescue
  • joined 25 Jan'20 - 9 messages
  • New Zealand
Bryan
So I was reading another post that stated "komatsu only used atf II or III in USA produced trucks (serial # ends or starts with an "A")
My serial# ends with an A and the fluid color was red. I plan to use some dexron III fluid I have on the shelf. I didn't get a chance to take a good look but does the ATF get filled thru the dipstick hole or is there a designated plug?
I will try to update as I progress
  • Posted 23 Jan 2020 23:00
  • By Romie_Rome
Lift Tek Elecar
edition #1303 - 15 October 2026
In this week’s Forkliftaction News , we report on a number of product launches including an Auto-Navigation Forklift Robot from Chinese equipment maker Leapting, developed for utility-scale solar construction sites... Continue reading
The term 'Genuine Leather' is not used to reassure you that the product is made of leather, but rather to indicate that the lowest quality of leather is used.
Lift Tek Elecar
Tommi Haavisto Tommi Haavisto
Director of sales, EMEA & APAC, Hiab and MOFFETT Truck Mounted Forklifts
Regional director for UK & Ireland, TVH
President - business area port solutions, Konecranes
President, Logisnext Europe
ORDER PICKING
FLEET MANAGEMENT
HIGH-CAPACITY FORKLIFTS
CHARGING INFRASTRUCTURE
SAFETY SOLUTIONS
