E-200
Error message, does not go forward or backwards...any clue?
  • Posted 27 Jan 2015 07:09
  • By mi_p_Inc
  • joined 27 Jan'15 - 1 message
  • Quebec, Canada
After repairing the field wire it still would only drive a few inches and code out either e142 or e200. I did another continuity test on the cables to motor and all good with no leaks to frame. So I replaced the drive controller and all is good now.
fyi
  • Posted 11 May 2016 10:45
  • By troy_m
Thanks I had the same and a e142 code. Removed handle found broken wire rubbed through just below sheathing.
  • Posted 6 May 2016 23:52
  • By troy_m
A-Lift Services -- safe -reliable -affordable
Broken field wire. Remove handle assembly to check.
  • Posted 27 Jan 2015 11:31
  • By EasiTek
Terberg YT222
Aichi SR18A
