Display Code L221
I have a Lansing Linde H40D that is displaying the code "L221" which effects the hydraulics. Can anyone assist. Thanks. Richard
  • Posted 19 Oct 2009 22:31
  • By fhsltd
  • joined 20 Dec'07 - 29 messages
  • United Kingdom
Get codes cleared and start over. Also seat switch could be bad. 232 might be brake switch and neutral safety switch which is under floor board on left side at brake valve. Might try getting switches calibrated.
  • Posted 8 Oct 2016 13:35
  • By edward_m
  • joined 11 May'15 - 111 messages
H30T, Hey I have a similar problem with 3 codes, L221, L222, and L232 currently I have no lift or tilt any suggestions, thanks in advance for your assistance.
Sam78
  • Posted 25 Sep 2016 01:17
  • Modified 25 Sep 2016 01:19 by poster
  • By sam78
  • joined 25 Sep'16 - 7 messages
I have rebuilt the tilt angle sensor. The two gears wear out. Need a laptop to calibrate. This starts happening at about 9000 hours when the tilt angle sensor starts showing this code. Sometimes it can be recalibrated and this solves the problem. check plug for broken wire
  • Posted 23 Jan 2016 13:56
  • By edward_m
Also check joy stick,if you have dual joy sticks, then just swap at plug to see if code comes up when tilting. hook up lap top and recalibrate first
  • Posted 18 May 2015 05:41
  • By edward_m
Hi Richard
L is a hydraulic fault and 221 is a faulty tilt pot,
If you check the pot you may find the plug has got a poor connection in it(dependant on the year)the earlier models had a non waterproof plug and can get moisture in.Just unplug it and give it a good clean with electric cleaner.
You can not get the early type pots they are no longer available if you order a new one it comes as a kit to convert.
If the plug checks out then check the wiring if all seems ok and the linkages are not worn then you may need a new pot,but you may need a laptop to set it up.
Hope this helps
Herald.
  • Posted 22 Oct 2009 05:21
  • By Herald
  • joined 3 Jan'07 - 128 messages
  • lancashire, United Kingdom
The term 'Genuine Leather' is not used to reassure you that the product is made of leather, but rather to indicate that the lowest quality of leather is used.
Elwell-Parker ESI500-36
Toyota 8FD30
Singapore
USD18,000
ORDER PICKING
FLEET MANAGEMENT
HIGH-CAPACITY FORKLIFTS
CHARGING INFRASTRUCTURE
SAFETY SOLUTIONS
