Crown RC30TT EV1 PMR trips
This lift truck will start and move in both forward and reverse. Once it gets going, it stops (PMT trip?) If I continue to puck on the joystick after a second or two. If it stops, I need to turn the key on and off before it will move.
If after starting, I return the joystick to center before it kicks off, I can repeat this start, coast, start, coast without triping the PMT.
Any ideas on what is most likely to.cause this?
  • Posted 21 Nov 2024 05:33
  • By Gary_Go
  • joined 21 Nov'24 - 1 message
  • Washington, United States
Gary_G
First do you have a GE hand set to plug into the control card to see if there is a code what is going on is the control card is seeing a fault and tripping the pmts. Without a handset it is very difficult to pin point the problem.
  • Posted 23 Nov 2024 11:21
  • By Scott_
Scott
Terberg YT223
UN Forklift FGL35T
