Clark turnover NOTfiring up!!
The unit sat around for years! Check plugs ok cleaned up and drop some trani fluid in the cylinders and roll over a couple of times,let sit for a day.So I top dead centre#1 cyl.set distrubor and the gap.
check spark wasn't strong like intermittent?check carb.clean out.
How do I check if propane is present? Any HELP !!
  • Posted 17 Feb 2013 07:33
  • By LOGIC
  • joined 6 Dec'08 - 70 messages
If you do not get even a whiff of odor coming out of the mixer (what you may call a carb), the regulator might not be "passing any gas".
You can check to see if the engine really "wants" to start by spraying about a 2 second burst of spray carburetor cleaner into the mixer and then cranking the engine over.
If the engine then acts as if it wants to run (for about a couple seconds) each time you spray the cleaner in, you definitely have a fuel delivery issue.
If, however, the engine still does not try to "fire" on this alternate fuel source, you may have an ignition issue instead...................or "also".
  • Posted 17 Feb 2013 08:01
  • Modified 17 Feb 2013 08:01 by poster
  • By L1ftmech
  • Tennessee, United States
Ancient Egyptian civilization lasted for so long - over 3,000 years - that by the time of the New Kingdom (c. 1550-1070 BCE) Ancient Egyptian archaeology was a career option.
edition #1284 - 4 June 2026
It has been a big week of product launches for the materials handling sector... Continue reading
