Charger/indicator not working
Guys. I have a Fiat Reach truck. I got it second hand and it was delivered and some people stole the charger from outside my unit.
The forks were fully charged when I got and the indicator on the forks went down with usage. When it got to flashing red it died.
I got a 48 volt charger called a Oldham Crompton and I had to buy the correct plug to go into the forks to charge. When charging the charger says a 4 digit number like 6083 next to it is a % sign. s I have no instructions for charger I have no idea what this means? I charged the forks overnight, the charger made all the correct noises (I.e it clicked into action about 20 seconds after turning on) and buzzed loudly.
The next day the forks seemed great. Loads of power BUT the flashing red Battery dead light on the forks is still flashing red even though its charged for hours. Can it be that as the charger is NOT the one that came with the forks the Charge indicator light will not work? The charger is single phase and going into my fuse box. is it possible its not getting enough currant? Even though the forks work I will never know when it's going to Die at this rate. Thanks
  • Posted 15 Jun 2017 01:56
  • By Jamesgs
  • joined 15 Jun'17 - 17 messages
  • kent, United Kingdom
Any link to a cheap one you know? Would one from Amazon do the job?
  • Posted 15 Jun 2017 23:47
  • By Jamesgs
A volt meter is the only real way to check this out.
  • Posted 15 Jun 2017 22:25
  • By BREWSKI
Morning. Thanks for the reply. Its made by Fiat but it has another name. I just could not see it in the list given.
I will be going into work and can name it properly later.
So do you think I should invest in a Voltage Meter? Then try the meter on the charger to see if 48v are coming out? Would I also be able to put it on the plug that comes from the batteries to see how "charged" it really is?
  • Posted 15 Jun 2017 16:46
  • By Jamesgs
Never worked an a Fiat lift but many BDIs will not reset unless the battery reaches a specific threshold voltage. Can you take a battery voltage reading before you use the battery?
  • Posted 15 Jun 2017 02:58
  • By BREWSKI
Terberg YT222
Taylor TX330S
USD159,500
Terberg YT222
Taylor TX330S
USD159,500
