CAT GC18K Full Free Triple Mast
The problem is the second stage (2 outside cylinders) lift before the primary ( front single cylinder) I lifted the mast to its max lifting height and it solved the problem..........but a few days later the customer says its doing it again. Anyone have this problem????? I am thinking of a flow divider of check valve. Any ideas would be appreciated thanks
  • Posted 13 Feb 2009 23:54
  • Discussion started by Prentice
Thanks Gentlemen for the great response. I have ordered the parts and will give an update when repairs are complete.
  • Posted 19 Feb 2009 23:53
  • Reply by Prentice
I would almost positive that repacking the cylinder, and while apart, replacing the cushioning valve in the bottom of the center lift cylinder will cure your problem.
  • Posted 17 Feb 2009 21:14
  • Reply by edward_t
Packing or valves in primary lift.Order both to be safe.
  • Posted 17 Feb 2009 07:38
  • Reply by proshadetree
  • Tennessee, United States
i still think its a dry or binding carriage rail (maybe bad side rollers)
but ive seen those valves go bad (in the piston rod not the fitting) and cause odd issues
so i was thinkin of the right thing but the wrong function :( lol
  • Posted 16 Feb 2009 23:28
  • Reply by justinm
If you had a problem in the down safety valve, the fitting on the left side secondary cylinder you would not have a staging problem, rather the carriage would lower slowly. That valve is to provide a metered flow that prevents the mast from crashing down. Note that the down safety valve is not a velocity fuse,that will stop the carriage completely, so if you were to have a broken hose or line you would get a mess. But that is not the problem in your case.
But also check for binding in the carriage or mast rails.
  • Posted 16 Feb 2009 12:31
  • Reply by jeremy_s
It sounds like you have a leaking up-stroke cushion valve. (Not a down safety valve) You will need to disassemble the free-lift cylinder and replace the check valve in the piston. If it leaks you will get fluid build up on top of the piston, it takes more force to push it out the check valve than it does to raise the inner mast rails, that is why the second stage cylinders will fully extend before the free-lift cylinder has enough pressure to force fluid out from the top side. This problem happens under normal conditions if the operator makes quick partial lifts. Under these circumstances fully extending the mast corrects the problem. Since it happened again I believe you need to replace the internal check valve, you will also need a free-cylinder packing kit since you need to dis-assemble the cylinder. I have had a problem where the check valve retaining ring (snap-ring) broke, thus causing piston damage. I needed to replace the piston also.
  • Posted 16 Feb 2009 12:22
  • Modified 16 Feb 2009 12:51 by poster
  • Reply by jeremy_s
oops my bad
it is in that fitting
im not sure which mast im thinking of hmm
  • Posted 15 Feb 2009 09:59
  • Reply by justinm
If you fully stage the mast you notice it will correct the mis stage problem, replace the fitting in the bottom of the primary lift cyl.
  • Posted 15 Feb 2009 05:41
  • Reply by tech
The hydraulic fluid will follow the past of least resistance so if the packing is bad in one of the side cylinders the fluid will go there first before the free lift cylinder. On a lot of "foreign" trucks there are tubes at the top of each cylinder that return to the tank. If you take off the tubes raise the mast all the way up and keep hydraulic pressure on it once it has reached full extension there should be no fluid coming out of the tube ports. If there is then the cylinder in leaking internally and the must be repacked.
  • Posted 14 Feb 2009 23:54
  • Reply by duodeluxe
  • United States
duodeluxe
grease the mast channels
they might be dry
dont use too much just get a thin layer on 1 side of each channel that the carriage rollers go in, the rollers will transfer the grease to the other side of the channel
too much grease can stall the rollers and cause damage to them and the mast channels
also make sure the side thrust rollers arent loose or broken and may be jamming up the works (again in the carriage)
theyre held in by 2 bolts each and they have grease fittings too
look for anything binding the free lift cylinder
in the bottom of the the piston rod itself there is the valve that limits the flow of fluid that can escape if the line loses pressure (burst)
maybe that has an issue
good luck
  • Posted 14 Feb 2009 10:40
  • Modified 14 Feb 2009 10:44 by poster
  • Reply by justinm
I think it is best to state what the problem is or was first.
  • Posted 14 Feb 2009 03:14
  • Reply by johnr_j
"Have An Exceptional Day!"
edition #1235 - 19 June 2025
UN Forklift FD35T
UN Forklift FBRP15NQZ2
Lift Technologies Inc.
