brake fluid
Hi I have a old C500HY55 that lost its brakes.Checked the reservoir which was empty and the fluid is red possibly transmission fluid?What should the brake fluid be
  • Posted 26 Jan 2018 07:22
  • By cwk2661
  • joined 26 Jan'18 - 1 message
  • British Columbia, Canada
sounds like contaminated or wrong fluid
like tom said, these trucks used DOT3 which is yellowish to clear depending on the brand.
you probably should go through the whole brake system
if someone did put transmission fluid in it then it will have to be drained, lines cleaned, wheel and master cylinders replaced.
If it has a slave cylinder for the inching that too.
  • Posted 29 Jan 2018 09:53
Brake fluid only (DOT3), if the system was filled with oil of any kind you may have swollen or damaged Master and wheel cylinder seals.
  • Posted 29 Jan 2018 08:24
  • By tom_p
  • Alberta, Canada
edition #1281 - 14 May 2026
Nils Altrogge Nils Altrogge
