BATTERY BOX SECURITY
Re Electric forklift battery box security.
I can not understand why manufacturers do not have a battery box retaining / locking system to prevent the battery box & its contents from shifting in the event of a roll over on counterballance units.
The power leads will arc our and be severd leaving the box & its contents to fly out.
should the forklift of the electric counterballanced tpye roll over there is nothing stopping the battery box from relocating placing forces onto the underneath side of the drivers seat.
such forces will result in the operator being pinned underneath the canopy or against the dash board or steering column.
my sincere hope is that some one in design areas will see this article and consider its contents
  • Posted 6 Feb 2005 08:38
  • By DANGEROUS
  • joined 6 Feb'05 - 17 messages
  • Queensland, Australia
"OUR BUSINESS IS SAFETY"
There are many forklift makes that use battery restraints as standard equipment on all their models, either due to the design of the hood (Toyota 5 series with latch) or through use of a removable bar that is chained to the truck so it cannot be removed (Toyota 2 and 5 series three wheeler).
  • Posted 24 Nov 2005 13:14
  • By steponmebbbboom
  • joined 21 Nov'05 - 191 messages
Good grief, charlie brown...
steponmebbbboom@hotmail.com
In Canada,
Safety regulations stipulate battery retainer mechanisms are mandatory for mobile equipment.
I once witnessed the aftermath of a forklift that rolled backwards off a dock and landed on its overhead guard upside down, the battery weight was too great for the battery cover and busted the hinges and slammed into the overhead guard, squashing the driver's seat to about 30mm thick and then leaking battery acid over everything.
If the young operator had not jumped clear he would have looked like stawberry jam squashed under that 3000 lb battery.
This concludes my lesson on "Battery Retainers 101".
  • Posted 25 Feb 2005 06:11
  • By Al_S
  • joined 30 Jul'04 - 20 messages
  • Alberta, Canada
Alberta Forklift Safety Council
Serious about safety!
I have seen the photo you mention and have innocently assumed the batteries had come out due damaged caused during the accident, as you suggest probably not so.
I find this situation remarkable, the batteries are heavy, full of acid and likely to squash and burn for all of the above reasons.
In the UK all road vehicle batteries are required to be secured for annual testing purposes, clearly vehicle batteries are always much smaller and lighter.
How can this be permitted?
  • Posted 9 Feb 2005 04:26
  • By rod_s
  • joined 31 Jan'05 - 9 messages
  • England, United Kingdom
To ROD_S
If you have a look in the Photo Galleries under Incidents & accidents you will see an electric "Trike" that has been rolled,
beside it you will see the battery box that has been ejected and the batteries that have come out of the box.
I do not wish to give the impression that I am criticising the brand depicted and I do not wish to name other brands because a simple quick look will surfice.
  • Posted 7 Feb 2005 13:30
  • By DANGEROUS
It is hard to believe that there is no provision for retention of the batteries, on any vehicle. Certainly batteries must be secured on any road vehicle in the UK/EC.
Is it possible to check with the manufacturer that nothing is missing/modified on this truck. Perhaps you could let us know the make & model so that other visitors can check their trucks?
Do you have a Government safety organisation you can refer the matter to in the event that this truck is "as supplied"?
  • Posted 7 Feb 2005 08:17
  • By rod_s
Terberg YT223
TCM FD115-3
edition #1284 - 4 June 2026
It has been a big week of product launches for the materials handling sector... Continue reading
