Backfiring Vortec
I have replaced the ignition system (as the factory & dealer suggested). As it was still under warranty at the time the dealer had to replace the mixer diaphram (it blew up from all the backfiring), the LP regulator and removed the intake and flushed it due the all the propane "honey". This is the only lift in the fleet I'm having this problem. If I **** the timing it quits backfiring as bad but the idle fluctuates badly. The dealer has thrown up their hands. Any ideas? Anyone else having similar problems?
  • Posted 25 May 2010 03:51
  • By joe_d
  • joined 25 May'10 - 253 messages
I recently had a Hyster with a Vortec that started doing the same kind of stuff you were saying. I'm not sure if your truck carries the same vacume governor set up like my hyster. But when i went through this problem theres a electronic controller that regulates the vacume going to the governor. When i checked the voltage it was spiking to 60Volts at times. When i traced the wiring someone had mixed a diagnostic wire with one of the coil wires so it was back feeding to the vacume electronic controller. after fixing the wiring the issue went away.
  • Posted 27 Jun 2010 04:59
  • By CLTL
  • joined 27 Jan'10 - 21 messages
The backfiring happens when quickly accelerating or getting out of the throttle and this blows the air cleaner cover off. It only backfires like this a couple of times a day if at all. The lift only has 1700 hours on it and it's the only one of it's kind in our fleet. The factory first stated that it was an ignition problem but after I changed all that now they say it's our propane but I'm not having any issues with any of the other LP lifts. I was talking to a friend who is still doing field service and he said he's having the same problem with a vortec powered Daewoo. Coincidence?
  • Posted 25 May 2010 22:28
  • By joe_d
sounds like early valve timing which can be caused by seats receding into head which acts exactly like over adjusted valves. most of the time this backfiring occurs when steering (which lugs the engine) and attempting to accelerate. occaisionally lowering the steering pressure will help. if the valves are opening early it should show up on a vacuum guage. (a really good diagnostic tool that everyone seems to have forgotten about). make certain even with new parts that moisture is not getting into the cap through tiny cracks. i have had this happen in the past. mist the cap with water and see if the problem gets much worse. can be a hard problem to find.....hope you get it knocked out soon
  • Posted 25 May 2010 09:05
  • By toyzilla
  • joined 29 Mar'10 - 175 messages
easier to ask forgiveness than to ask permission.
Stu Jacover Stu Jacover
Chief executive officer, TVH
US forklift tariffs now 15% Washington, DC, United States
Aichi SR18A
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
edition #1285 - 11 June 2026
