2.0 mazda valve clearance
I have a 2009 hyster h30ft that has a Mazda 2.0 (9z9xb02.2ztl) (4) cylinder motor lp. Does any one have the specs for valve clearance. hot and cold.
Thanks!!!
  • Posted 16 Jul 2016 07:29
  • By Gator
  • joined 3 Oct'14 - 45 messages
This sounds like a regulator problem. If it sat for a long time the regulator may not be functioning properly after it goes into closed loop mode.
  • Posted 29 Jul 2016 22:44
  • By BREWSKI
I'm pretty sure its fuel. I can start it no problem with starting fluid until I can get my hand to hold the throttle down then i transition to my hand to my foot (its a real pain in the ***). then I have to keep the throttle down about 1/2 way at all times or it will stall. all fuel components are warm not frosted or cold.
This lift has been sitting for 2 years. When I first did compression check it had 30-60 I sprayed seafoam and also some marvels mystery oil on valve springs and pushed them down. It must have cleaned the valves up enough to get them to function right because now compression is 180 each cylinder.
  • Posted 22 Jul 2016 13:17
  • By Gator
Depends on if you are loosing spark or fuel.
  • Posted 21 Jul 2016 22:18
  • By BREWSKI
They are rounding the measurements to the nearest thousands.
  • Posted 21 Jul 2016 22:17
  • By BREWSKI
well... strange
i get a different adjustment gap from the manual for all mazda 2.0L and 2.2L engines for trucks H30FT beginning serial number F001
INTAKE (ENGINE COLD): 0.15 mm (0.0059 in.)
EXHAUST (ENGINE COLD): 0.35 mm (0.0138 in.)
when i check the technitians quick reference guide it does give this:
Intake 0.15 mm (0.006 in.)
(COLD)
Exhaust 0.35 mm (0.014 in.)
(COLD)
is this a typo?
i know the measurements are very close but this can be confusing to those that do not know.
  • Posted 21 Jul 2016 20:40
  • Modified 21 Jul 2016 20:49 by poster
do you know what would cause this lift to go into shut down mode right after i start it?
  • Posted 21 Jul 2016 11:44
  • By Gator
Thanks!!
  • Posted 21 Jul 2016 11:40
  • By Gator
.006 in. intake,.014 in. exhaust. These are set cold.
  • Posted 21 Jul 2016 01:48
  • By BREWSKI
Sue Tomic Sue Tomic
ROYPOW
Sue Tomic Sue Tomic
