New STILL electric three-wheel trucks
- 28 Apr 2011 ( #511 )
7 min read
It is the greatest amongst the small - and still the most compact: the new RX 50 electric truck from the Hamburg based lift truck manufacturer and intralogistics company STILL.
Today, the "50" already stands for the most sold three-wheel electric truck with rear wheel drive. In the future this is the way we want it to stay so therefore we have made it even better for more efficient transport of material. The introduction of the new model will ensure that the tradition and unique success continues for 24-volt electric three-wheel trucks made by STILL. "It runs and runs and runs!", is something that can also be said about the STILL three-wheel truck. The R 50/RX 50 is the most sold three-wheel electric truck with rear wheel drive worldwide. Altogether more than 90 000 units have been sold all over the world since 1977!
But the success story begins much earlier: 1949 - with the EGS 1000 electric three-wheel truck which was the first series of STILL trucks in the market and by this the first of its kind.
The new RX 50 series impressed the experts right from the launch date. The result: the IF-Product Design Award 2011. Winning this award is proof of the successful combination of form, function and features. The driver is motivated by a user-friendly workspace. The new RX 50 is the most compact truck of its class with load capacities from 1.0 to 1.6 tonnes. Its narrow working aisle width saves space, leaving more room to store goods.
Flexible applications
The RX 50 is a very agile all-round truck for every warehouse or area of production where it is necessary to stack and transport material flexibly, for example in the marshalling area of warehouses with often small or narrow aisles or when loading and unloading lorries or containers. The broad range of possible applications include food and drink manufacturers, printers, third party logistics, goods in and out as well as multi-shift operation in the automotive industry, for example, to provide material to production lines.
Even if space is especially limited - the RX 50-10 COMPACT will fit in. A working aisle width of 2888 mm speaks for itself. With an overhead guard only 1980 mm high and a chassis width of only 990 mm, it easily travels through doors only two meters high and one meter wide.
The environment benefits as well
The new RX 50 features the energy saving feature Blue-Q as standard, saving up to 12 percent energy depending on the application and the equipment of the truck. This is not only a plus for the environment, because each Kw hour saved, does not only save 575 grams of CO2 (according to Umweltbundesamt, CO2-emission factor 2009 in the German electricity mix, as per March 2010) but also means lower energy costs saving up to 1000 Euros (operation time five years and three shift operation).
User-friendly
The driver feels at home right away in the seat of the new RX 50. He will find all the comfort he knows from its big brothers RX 20 and RX 60 in the compact RX 50 also.
The large grab handle facilitates safe and easy access when entering and leaving the truck. The driver has every information available at a glance and the hydraulic controls are easy to operate. The display and control unit gives the driver direct access to the driving programmes, the spotlights, the windscreen wipers and much more. Depending on the application or the load, the driver can select the most suitable of five available driving programmes. The sensitive driving characteristics and the exact execution of all drive commands increase operational safety.
Large windows in the overhead guard ensure optimum visibility upward and forwards for faster and safer operation - a standard throughout all the STILL trucks.
The driver's compartment, complete with the control concept is uniform for all the electric and diesel trucks of the RX series. This wayeach driver can operate all STILL trucks equally well. The effort needed for training and familiarisation is reduced to a minimum. The drivers do not have to get re-accustomed when they change trucks.
Individually adaptable to the driver and the application
The operator can easily adapt the equipment of the RX 50 to suit their individual operational demands. For example, there are four versions of hydraulic controls available: multi-lever, Fingertipp, mini-lever or Joystick control. This adaptability to the wishes of the driver is offered exclusively by STILL.
Optionally the mast vertical positioning feature is available. If activated, the mast stops in the upright position when tilting forward. This is helpful to quickly stack or de-stack pallets, especially at the higher levels of the racks.
If the load weight needs to be known: the optional load weight sensor has a precision of +/- 2 percent. The load weight is indicated on the display. Depending on the place of the application, different overhead guards are available for drive-in racking, to travel under low doorways or to access train carriages. The canvas cabin protects the driver when working outdoors.
Everywhere available
Optionally the battery can be changed at the site of operation and without the need for a hoist. Driving to and from a central charging station becomes unnecessary and the time saved can be used for productive work. All the maintenance inspection points are easily accessible. The battery cover can be readily unlocked and opened with one hand with the help of a gas pressure spring to reveal the battery and the electric components. Capsulated (IP 54) and maintenance free AC electric motors for drive and hydraulics ensure that the RX 50 operates reliably in dusty or humid environments Maintenance is only required every 1000 hours of operation or every 12 months.
System orientation
The RX 50 is a great team player. Optionally it can be integrated into a transport control system. To do this, respective terminals and scanners, for example, the 8.4 inch Touch Terminal are available. Good material flow management optimises the travel routes, avoids empty journeys and allows paperless transport of information parallel to the transport of material. Fleet operation: Optionally it is possible to integrate the truck into the FleetManager. This software offers access authorisation, an accident recorder and the evaluation of truck data and operation data.
Convincing design - having won a trophy already!
The new RX 50 was awarded the much coveted iF-Product-Design Award right at its market launch. The panel of experts was convinced of the benefits the consistent family design has to offer, because another three STILL products were also awarded the coveted IF-Product-Design Award 2011. (The EXU-SF low lift pallet truck, the EK-X vertical order picker and the RX 70 diesel forklift truck). The award-winning design of the RX 50 is the result of the long years of cooperation of STILL with the Hamburg based design office TEAMS DESIGN. The family design is unmistakeable despite each truck having been designed for different areas of application.
THE NEW RX 50 FROM STILL. NOW ON YOUR IPADTMAND IPHONE®.
The new compact RX 50 electric fork lift truck from STILL. Experience the highlights of the new STILL RX 50 with the interactive iPhone and iPad app.
  • View the RX 50 in detail from all angles with the 360° view.
    Discover all applications and highlights of the new RX 50, including the user- friendly display-control unit, the protected driver roof with enhanced view, or the four innovative control options in the gallery.
  • Learn more about the STILL range of products and services. Read up on the STILL PartnerPlan, the STILLReport, the comprehensive STILL Service and the STILL company philosophy.
  • Take a look at all the technical information for the RX 50 electric forklift truck.
  • Share information with others via e-mail, or get in touch with us directly.
Download the free app from the App StoreSM.
Visit us at the CeMAT (2 to 6 May 2011) in the outdoor pavilion P35.
For mote information please contact,
STILL GmbH
Berzeliusstraße 10
D-22113 Hamburg
t: +49 (01804)-7 84 55 33
f: +49 (0180)-200 62 00
e: info@still.de
w: www.still.de
Or click to view the STILL ShopFront
Oxford Ct, United States
